  • Member For: 14y 7m 23d
With a escort really your best bet and one of the simplest conversion's would be a Mazda 13BT. Even a stock turbo motor in that car would be a weapon.
  • Member For: 17y 11m 20d
Ive seen pics of one before in a cortina...I think it was on fordforums.com.au
  • Member For: 18y 8m 17d
Its been done in an escort,, firewall has to be cut or else its impossible
  • Forged Member
  • Member For: 18y 4m 7d
I had a good look in the engine bay of an escort with a Nissan FJ20 motor in it - barely fit at all...
You would definitely need to modify the firewall to fit the Barra - plus the height of the motor would be tricky too, they are very tall with the win cam head and big 7L sump
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 5m 29d
eskies have pretty small engine bays.
I wouldn't recommend anyone to do a Barra into an Escort as their first engine conversion, think something simpler.
you also won't get it engineered in NSW at least, probably not anywhere so it would be a drag car only (not a track either as it will handle like ass without huge commitment)
otherwise:
motor mounts
gearbox x member
radiator & intercooler clearance mounting
firewall mods
steering box or rack clearances
sump
manifolds
water plumbing
air plumbing
tailshaft
shorten a strong diff
handbrake issues
brake fluid lines
massif brake upgrade
ECUs
more
more
more
what a headf*ck, just buy a XR6T and enjoy it.
divorce is likely between step 4 and 5 when you realise what you've started.
Edited by SuckSqueezeBangBlow
This is the one im talking about
Motor-
xr6t motor(not finished yet)
gt47 on methanol
got a built c4 but going to buy a clutchless geforce or liberty
diff is a crome-moly sheetmetal 9inch, 4link, strange coilovers. full cage( chassis was done by street neat welding)
15x12 magnums with 29x15.5 mickey t street rubber.
here's a couple pics of the dash getting done.
  • Like 2
  • Member For: 13y 9m 28d
Lol at firewall clearance I doubt any engineer would ever let something like that onto the road, I would do the cortina personally and im pretty sure castle maine rod shop do the chassis kits for the v8's that are engineer pre approved so would be alot easier to get the turbo 6 on the road ie the chassis kit meets engineer specs for thickness and strength all that stuff good luck
  • You've changed man....
  • Member For: 14y 5m 18d
is your heart set on an escort?
Would you even consider goin the cortina?
Man lookin at them pics, id love to take on a project like that...
Barra motor into a light car is the ultimate, youd run 9.4's in a capri with 360rwkw, if I was loaded that would of been the 1st thing I would of done.
Edited by xr6t_ute
  • Like 2
