How Quickly Should Engine Oil Take To Go Dark Or Black?
NickBA-XR6T
  • Member For: 22y 3d
You Guys do realise that oil going dark is also a very good sign the oil is doing its job!
And it can also be a sign that something is very wrong with the engine. Excessive camshaft wear comes to mind in making black oil. Now let that play on your mind.
  • Member For: 16y 4m 11d
Castrol edge, available at your nearest super crap or repco with a discount for RACV members. Doesn't cost the earth.
Edited by Paulie2256
  • Turboless
  • Member For: 14y 1m 6d
Never read a bad thing about royal purple but forget the price. But am definitely putting a very decent oil in my next car..you might be a good source of info for me jet :) haha
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 2d
maybe this ones over my head aswell
just SMASH MY DATE to 23psi in the mid
a multitude of things can be in play piston ring and oil ring wear bit of blow by blackens oil , oil pump gears heavely worn big end bearings damaged the list goes on but when comparing such workings on a fairly fresh donk the oil has to stand up or phuck off, nothing like a bit of chocolate custard in the sump,
next thing some may hate it but iam a big fan of the old engine oil flush 15-20min b4 droping old oil and then leaving it to drain for an extended time 1 hr is good every last drop
Edited by Dagabond
  • Like 2
  • Member For: 15y 5m 9d
I have read somewhere that nulon 'synthetic' oil is actually not a true "fully synthetic" oil. Could this be the cause of it going darker sooner due to the high turbo temps and all?
castrol edge 10w60 here in a 47000km bf f6, I could re-sell the oil as new when I dump it at 5000km's.
  • Member For: 15y 2m 15d
Totally agree with you jet about fuchs being a great oil for the money, I use to use it and it was brillant the whole time I did use it. I now use elf as I can get it for a really good price and it is simply the next step on from Fuchs but its only a small step better. When I changed to the Fuchs from the factory oil that was a huge step up in quality.
Full syn oils have a better tendancy not to blacken due to all the special stuff in them to prevent it. Oil blackening can also be a sign that the oils components (as such) have broken down and that it is no longer doing its job. This can be quite typical in a turbo type vehicle when not using full syn or not good enough full syn.
