  • BANNED
  • Banned
  • Member For: 18y 2m 10d
  • Gender: Not Telling
If I remove my front and rear windscreen, will the air going straight through make me go faster as less wind resistance?
Depends if the hoodlining is black or not?
  • I <3 Floods
  • Member For: 13y 11m 7d
Also on weight reduction.. Impellor may of reduced wheel weight by 1.6kg.. But if he did it without using power tools.. Bit of exercise in that.. He might've dropped another kg from physical exertion.
  • Thooperrrrrrr
  • Member For: 14y 6d
Cannot believe I have just noticed this informative thread.
Interior light and door lights + covers, there's a good 60 - 100g loss in weight. Remove tint and fuse box cover also
  • Member For: 18y 9m 10d
The mat on the bonnet,, heat sheild or sound deadener?
  • Member For: 14y 8m 16d
What if I got the guys from mythbusters to hook up my car like a radiO control car? Then with me out of car and controller in hand just send it down the qtr mile like that?
To answer your question most spray packs/cans are 400ml. Now you have a rough cast wheel (which needed to be sanded 12 times, after you have removed all paint) that has primer filler, colour and clear coat. Now I'm unaware of the specific gravity of paint but lets say 1ml = 1gm.. I also consider this is conservative because I would think that paint has a higher specific gravity than water. Is it unreasonable to think that when painting 4 wheels that you would use a total of 4 cans. 1 for filler, 1 for clear coat and 2 for colour Therefore 4 X 400ml = 1.6 kgs. Do you still think there would need to be 10 coats? Further, this doesn't take into consideration that you are sanding the wheel 12 times. Hopefully this makes sense.
As I have previously stated the wheels were polished for looks not weight reduction. But I was interested in the weight difference, because I understand the benefits of reducing static weight. Cheers
You be better of going on a diet impellor and losing 10kg. The time and effort is beyond me really in sanding and polishing a stock wheel as they look $hit anyway.
  • Member For: 19y 1m 11d
you would think that would well, with all the above modifications done and the rc controller wore one of the helmets pictured above
  • Member For: 15y 8m 13d
what would you know Pazzo? you don't even have a xr6t farken
Edited by sexual harrassment panda
  • Like 2
  • Member For: 14y 10m 10d
well seeing in this vid http://www.fordxr6turbo.com/forum/topic/80356-ferrari-458-italia-vs-ess-vt625-supercharged-e92-m3-vs-switzer-p800-gt-r-vs-modded-c6-z06/
it stated "160lb passenger" on the runs, with Pazzo being 260lbs I would say so....
LOL 160lb passenger! as if that makes a damn diff when the car has that much power....
Edited by JGP
