ratter Member 6,793 Member For: 18y 9m 14d Gender: Male Location: @ my laptop Posted 31/05/12 09:04 AM Share Posted 31/05/12 09:04 AM On 31/05/2012 at 8:59 AM, PAZZOnegger said: Wipers won't work with glad wrap,will get caught to easy. On 31/05/2012 at 8:59 AM, STAINOnegger said: glad wrap = parachute...your being sillylol you two fail, if you had been paying attention and now had a dimpled surface leading up to the windows, we would realise that there is no actual pressure on the gladwrap as the dimples have created a cushion of air which is deflecting the air pressure. 1 Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 2m 14d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 31/05/12 09:10 AM Share Posted 31/05/12 09:10 AM like upside down hovercraft? hmmmmm... Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 14d Gender: Male Location: @ my laptop Posted 31/05/12 09:13 AM Share Posted 31/05/12 09:13 AM (edited) dimples in the sump, gearbox, fuel tank, stone trays etc will creat this hover craft affect, not much good for a car that has to go around corners or turn a little, which is why it is better to do it on the normal exposed surfaces Edited 31/05/12 09:14 AM by ratter Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 7m 18d Gender: Male Location: Victoria Posted 31/05/12 09:15 AM Share Posted 31/05/12 09:15 AM (edited) I CANT BELIEVE MICK BOUGHT SECOND ORDER DERIVATIVES INTO THE MIX...THE GUY CAN TUNE CARS AND IS A f*ckING MATHEMATICAL GENIUS! I'M PUTTING ON MASSIVE RIMS WITH HUGE TYRES AND MINITUBBING...I WAS TOLD THAT IF I RUN MASSIVE TYRES, THE EXTRA SIZE IN CIRCUMFERENCE WILL BRING MY 1/4 MILE DOWN BY HALF IF I CAN DOUBLE THE DIAMETRE... PI x DIAMETRE GIVES CIRCUMFERENCE... MULTIPLY DIAMETRE BY 2, DOUBLE CIRCUMFERENCE... EVERY TIME THE WHEEL GOES ROUND, TRAVEL TWICE AS FAR... SAME RPM AND YOU HALVE YOUR 1/4 TIME!!! :paint:THIS IS WHY THEY RUN THE MASSIVE f*ckERS ON THE 5 SECOND CARS! THEY RUN 10'S WITH 275/40/17 MT STREETS I CANT BELIEVE IT TOOK ME THIS LONG TO FIGURE IT OUT? :wizard: Edited 31/05/12 09:17 AM by Worm 1 Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 19d Gender: Male Posted 31/05/12 09:16 AM Author Share Posted 31/05/12 09:16 AM Could I drill extra holes into my disc brakes without effecting strength? so if there already crossed drilled, can add another say 100 holes per disc to save weight. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 15d Gender: Male Location: Melbourne Posted 31/05/12 09:18 AM Share Posted 31/05/12 09:18 AM 2 Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m 21d Gender: Male Location: Vic Posted 31/05/12 09:20 AM Share Posted 31/05/12 09:20 AM (edited) On 31/05/2012 at 9:03 AM, tab said: Yeah ratter...you take it just that one little bit too far. I hope this thread stays out of google's search index. Might have to move it to the lounge shortly before the spiders get here.May get a few more donations if you leave it out for night. Something mrs freaky.Ps it looks like mick has seriously given this thought. Edited 31/05/12 09:22 AM by Henz 2 Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 7m 18d Gender: Male Location: Victoria Posted 31/05/12 09:22 AM Share Posted 31/05/12 09:22 AM On 31/05/2012 at 9:18 AM, Dillz said: f*ckING WASN'T ALL CAPS LOCK Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 14d Gender: Male Location: @ my laptop Posted 31/05/12 09:29 AM Share Posted 31/05/12 09:29 AM On 31/05/2012 at 9:15 AM, Worm said: I CANT BELIEVE MICK BOUGHT SECOND ORDER DERIVATIVES INTO THE MIX...THE GUY CAN TUNE CARS AND IS A f*ckING MATHEMATICAL GENIUS! I'M PUTTING ON MASSIVE RIMS WITH HUGE TYRES AND MINITUBBING...I WAS TOLD THAT IF I RUN MASSIVE TYRES, THE EXTRA SIZE IN CIRCUMFERENCE WILL BRING MY 1/4 MILE DOWN BY HALF IF I CAN DOUBLE THE DIAMETRE... PI x DIAMETRE GIVES CIRCUMFERENCE... MULTIPLY DIAMETRE BY 2, DOUBLE CIRCUMFERENCE... EVERY TIME THE WHEEL GOES ROUND, TRAVEL TWICE AS FAR... SAME RPM AND YOU HALVE YOUR 1/4 TIME!!! :paint:THIS IS WHY THEY RUN THE MASSIVE f*ckERS ON THE 5 SECOND CARS! THEY RUN 10'S WITH 275/40/17 MT STREETS I CANT BELIEVE IT TOOK ME THIS LONG TO FIGURE IT OUT? :wizard:wrong wrong wrongyour on the right track with the rolling diameter theory, but running a really wide sticky tyre will cause to much drag from the surface friction, not an issue when a top fueler makes 7000 + hp (or should that be +++++++ hp?), if you run a wide sticky tyre on anything with less that 3501.7 rwkw you will lose mph because of this surface drag, the secret to this is oil squirters under the rear gaurds to lubricate a percentage of the tyre so there is less drag. Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 7m 18d Gender: Male Location: Victoria Posted 31/05/12 09:31 AM Share Posted 31/05/12 09:31 AM f*ck me... I think I know everything... then Mick comes along and shines a light on me...Thanks Mick... Link to comment Share on other sites More sharing options...
