Highest Power Fg - Standard Turbo
b-rad
  • Member For: 12y 8m 24d
Just curious have any of these high dyno rated fg's used camshafts ?
Or they get 330 on 98 and 360 on e85 without a cam.
Would the camshaft be able to help while the smaller fg turbo is at its max ?
ye I know cams isnt needed, but I was thinking when the time comes for valve springs I might get a cam in there aswell
they sound nice plus reduces the amount of boost needed to make certain amount of power, from what ive seen crow cams show on youtube
I feel asif ppl are against cams around here lol
just say for the sake of the scenario;
im getting 360rwkw on e85 on max on my fg turbo
if I had a cam installed id get 360rwkw with less boost
then would I be able to put up the boost and go over 360rwkw barrier ?
  • Member For: 16y 1m 21d
shy, in this scenario pinging really a factor since the stock cams will be able to retard or advance the timing enough to find the limit on a stock bottom end.
they only reason I would upgrade the cams is if I have come to a point where the pcm can no longer keep up. This is at the 7k+ rpm.
No one does the cams because it really wont give you much (if any) benefit over the stock ones. In fact, you will probably gain power in the top end but loose power in the bottom, or vice versa so it is kind of a step backwards.
  • Turboless
  • Member For: 13y 10m 15d
That meant to be "not really a factor"? Or it is right how it is? Lol :/
