Turbo Ticking When Cold, Lacking Boost.
Kirty23
  • Member For: 12y 8m 21d
Hi guys first time poster...
Have a ba xr6 turbo '05
When car is still cold, I get a ticking noise coming from my turbo (I think). Once car is warm, it disappears. I researched this and thought it was loose bolts on the turbo- checked but found nothing. Was hopin some one could describe which bolts they are, or if that even is the problem.
I am also havin a boost problem. Turbo is going, but not getting the power I thought I would. Had a mate take it for a spin and said feels like I'm getting no boost at all.
Would appreciate some good advice
Thanks guys
  • Member For: 14y 5m 12d
Pull intake off turbo, spin turbine with fingers and see if it is touching anywhere, also shouldn't have much movement up/down etc. if its touching or moving excessively its stuffed, if not continue on looking for boost leaks in intercooler piping etc. Have u taken filter out of turbo oil line? Noise could be coming from lack of oil to turbo.
  • Member For: 16y 2m 25d
Exhaust leak?
Check exhaust manifold - engine bolts
Then
Exhaust manifold - turbo bolts
Then
Turbo - dump pipe bolts
You may also have a collapsed or blocked cat.
Edited by Paulie2256
