new370 Member 57 Member For: 17y 2m 27d Gender: Male Posted 31/05/12 10:31 PM Author Share Posted 31/05/12 10:31 PM yep, a rodent. just not sure if I swap an icc from another car if that will work and demonstrate if the problem is within the icc or will it not work anyhow from a different car? Link to comment Share on other sites More sharing options...
new370 Member 57 Member For: 17y 2m 27d Gender: Male Posted 31/05/12 10:41 PM Author Share Posted 31/05/12 10:41 PM Holy crap! He has to have chewed some wiring... Pull the dash out and have a lookthe dash? or the icc? fault is that the radio and a/c controls are doing strange things. steering wheel controls function as in the volume and stations change and scan from the steering wheel but the display is all crazy. do u think there may be a dash problem? we removed the icc, and checked it out. there is nothing obvious, no evidence of the mouse anywhere on the icc..... opened the covers and looked inside the radio etc but no corrosion, wee etc. I guess my main question now is if anyone knows if I can swap another icc from our other car to prove if its the icc or other wiring? Not sure if this would be compatible without ford programming it? If that makes sense... ie if the exchanged icc wont work in a different car anyhow, then it wouldnt be able to prove our point. I also wouldnt want to have to get ford to program it then program both of them again when I swap them back... just not too sure about that, so it would be good if anyone can advise. Again, thanks for all the input. Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 18d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 31/05/12 11:27 PM Share Posted 31/05/12 11:27 PM Is it faster without all that rubbish? Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 9m 20d Gender: Male Location: Brisbane Posted 31/05/12 11:31 PM Share Posted 31/05/12 11:31 PM Fck me!You can swap the ICC but will need to get it re-programmed before the car will run and the ICC will work. Link to comment Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 16y 1m 8d Gender: Male Location: 720 East Kensington Road Posted 31/05/12 11:40 PM Share Posted 31/05/12 11:40 PM Pull the ICC first and check the main wiring loom connected to it before trying to swap the ICC over, but to get the new ICC working you need to swap the very top white box and the very bottom one as well, this should allow the new ICC to work without reprogramming from ford. Done this a couple of times and each time has worked for me Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 18d Gender: Male Posted 01/06/12 12:08 AM Share Posted 01/06/12 12:08 AM Theres a number of looms that run behind the dash it couldve chewed, only accesible by removing the dash, its easy to pull out Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 11m 18d Gender: Male Location: Geelong, Victoria Posted 01/06/12 12:18 AM Share Posted 01/06/12 12:18 AM Agree with bionic. Pulling the icc out won't give you an idea on how the looms are behind the dash where the mouse could've accessed. Pita of a job but wouldn't be surprised if wiring back there has been used for lunch Link to comment Share on other sites More sharing options...
new370 Member 57 Member For: 17y 2m 27d Gender: Male Posted 01/06/12 12:28 AM Author Share Posted 01/06/12 12:28 AM Is it faster without all that rubbish?yep, I guess this is the true definition of a 'ratrod'!!Agree with bionic. Pulling the icc out won't give you an idea on how the looms are behind the dash where the mouse could've accessed. Pita of a job but wouldn't be surprised if wiring back there has been used for lunchok here goes, out comes the speedo...this should be much easier than pulling the icc nothing chewed behind the icc thoughTheres a number of looms that run behind the dash it couldve chewed, only accesible by removing the dash, its easy to pull outok will do today, thnksPull the ICC first and check the main wiring loom connected to it before trying to swap the ICC over, but to get the new ICC working you need to swap the very top white box and the very bottom one as well, this should allow the new ICC to work without reprogramming from ford. Done this a couple of times and each time has worked for mehave checked the wiring loom down the bottom where the 4 connectors are. all looks untouched. there are differing opinions on whether changing the icc will need to be reprogrammed by ford... if you think this will be ok by swapping the two modules ill give it a go. any others have experience with this? im trying to avoid having two icc's which dont work in the 2 carsthanks againFck me!You can swap the ICC but will need to get it re-programmed before the car will run and the ICC will work.have you heard some opinions on here that you can swap the two modules and then the icc should be swappable and therefore prove it working or not.thanks Link to comment Share on other sites More sharing options...
new370 Member 57 Member For: 17y 2m 27d Gender: Male Posted 01/06/12 12:41 AM Author Share Posted 01/06/12 12:41 AM NOTE:I thought I should mention for any future readers of this thread, that ive been warned about turning the ICC upside down (or even on a great angle). Take great care when removing this...if you drop it or invert it, apparently you need to throw it away because of the rollover sensor inside which will blow the electrics when re-installed (rollover safety feature). There is a sticker on the ICC from Ford, saying discard if dropped, but you dont notice that sticker until you have it removed and by then you may have turned it over. WARNING. Link to comment Share on other sites More sharing options...
TonezXR6T Italian Stig!! Donating Members 1,096 Member For: 14y 18d Gender: Male Posted 01/06/12 01:33 AM Share Posted 01/06/12 01:33 AM Looks like riffs filter :S that smell coming threw the car omg, making me sick 1 Link to comment Share on other sites More sharing options...
