Constant Rough Idle And Miss At All Temps - Help Please!
NickBA-XR6T
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Yeh mine is doing the same thing!! Was thinking 02 sensor but apparently it shouldn't be rough when cold if it was from a dodgey sensor. Tried leak teasting and couldn't find anything wrong, intake mangold gasket maybe but my car is only 60,000km old. Do ya rekon an inlet manifold gasket would give way that early bionic?
  • 2 months later...
  • Member For: 12y 7m 1d
My 2002 Ba xr6t I bout a year and a half ago with 155 thousand on it and about 20,000 ks after that pretty much as soon as the dealership warranty ran out my car started doin the brrrr under boost and got worse.Took it to ford and they did a diagnostic and said it was coils,changed them and sparkies and electronic boost controller,all good.10,000 ks later its back again and ford wanted another $120 for another diagnostic,yeah bullsh*t so ive delt with it for the last 20,000 ks,frustrating but ive cleaned the boost solenoid numerous times and throttle body and have new ngk sparkies and since hitting the 200,km point my car is now getting the rough idle.started off worse as the car got warmer but now itl do it all the time,on cold start shel misfire for about 2mins till it warms up cos ul here the exhaust caughing if u stand at the back.and if u give it a lil rev to 2000 rpm and take your foot off itl drop to 1500 and sit there for 5 seconds then drop to a 1000 and then slowly down to 700 so its missing hardcore and I dont know wat else to look for.
  • Member For: 14y 1m
x3 on the inlet manifold gasket. check the tension on the inlet manifold bolts and see if they are tight...sounds alot like an inlet manifold leak but its just a guess. it can happen with our cars
The only mods to my car that I know of is a blitz supersound bov and that's it, ford were gonna put their coil packs in but I had actually just got some off ebay that day and I think they were Mitron or similar so im starting to lean towards they are flogged after only 15,000 which is dissapointing but they aint genuine coils,I may be buying a set of genuine coils very soon but wanna pin point it before throwing more money around
