NickBA-XR6T Bronze Donating Members 386 Member For: 12y 10m 14d Posted 24/05/12 10:51 PM Share Posted 24/05/12 10:51 PM Hi Guys,Have had my 03 BA XR6T for about 2 months now. Since I got it there has been a constant rough idle and slight miss no matter what temp. I have replaced spark plugs, coils, cleaned the throttle body and checked as best as I can for air leaks. So far I have not been able to fix the problem. I have reset the ECU, reset the VCT, changed the fuel and air filter. Really starting to run out of ideas.Does anybody know anything more I can try? It doesn't break down under load, in fact it goes quite nicely when I accelerate or cruise. Kinda stumped.RegardsNick Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 7d Posted 24/05/12 11:26 PM Share Posted 24/05/12 11:26 PM It could be your turbo side engine mount...I have had a similar problem...they tend to leak after a while due to the heat off the turbo...simple check would be to accelarate and apply brake at the same time and check to see if the engine lifts excessively...do it in both drive and reverse...(and try not kill anyone including yourself...) Link to comment Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 12y 10m 14d Posted 24/05/12 11:48 PM Author Share Posted 24/05/12 11:48 PM Leak? I'll do what you said and see if the engine moves too much. Are the mounts filled with fluid or something? Link to comment Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 12y 10m 14d Posted 25/05/12 12:00 AM Author Share Posted 25/05/12 12:00 AM I should also say, the rough idle is not just engine shudder, but the revs actually dip and the needle bounces. Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 7d Posted 25/05/12 01:06 AM Share Posted 25/05/12 01:06 AM The mounts are fluid filled...if revs are going up and down then it wouldn't be your mounts...if its a BA it coud be your TPS. Link to comment Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 12y 10m 14d Posted 25/05/12 01:47 AM Author Share Posted 25/05/12 01:47 AM It may be the TPS, that's about the last thing I can think of. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 4d Gender: Male Location: SE Melbourne Posted 25/05/12 03:11 AM Share Posted 25/05/12 03:11 AM Is the tps triangle shape or curved? Link to comment Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 12y 10m 14d Posted 01/06/12 12:41 AM Author Share Posted 01/06/12 12:41 AM Will have a look and let you know. Link to comment Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 16y 11m 20d Gender: Male Location: Perth, WA Posted 01/06/12 08:28 AM Share Posted 01/06/12 08:28 AM Hey Nick,It's interesting but I've been having some similar drama's lately with my car... Did coils, plugs, cleaned TB and everything all no less than 15,000km's ago. I've done everything you have as well... My needle does bounce as well... Sometimes when she idles after a drive she feels like she's gonna bottom out. (Is you car, by chance an absolute pig to drive when she's cold? )I hope for both our sakes that it is the TPS - I'll be following this thread closely Can we check the TPS ourselves or do we need to take it into a shop?Mine still goes like a bat out of hell, but these other drama's are annoying me...Good luck mate Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 2m 21d Gender: Male Location: Muswellbrook,NSW Posted 01/06/12 08:32 AM Share Posted 01/06/12 08:32 AM SCT livelink Link to comment Share on other sites More sharing options...
