chris_richo Member 8 Member For: 14y 4m 27d Gender: Male Location: port macquarie Posted 24/05/12 11:16 AM Share Posted 24/05/12 11:16 AM hey guysI am proud owner of an 04 ba xr6t ute for around 2 years now and just recently the car has developed a weird idle problem. when I push the clutch in it idles at around 1400 rpm until you full stop rolling then drops back to normal (800rpm) and also has slight popping sound on normal idle. car starts and runs fine when cold, its when it warms up the high idle starts.car has been tuned for a year now with sct flash tuner, bigger injectors, valve springs, full xforce exhaust, hdi gt2 intercooler, fpv intake, 13 psi, 295 rwkw and loving itI've tried cleaning throttle body and checked the gasket is'nt leaking, checked for vac leaks, disconnect battery for 30 mins, cranking the car over for 10 secs with pedal flat, had no luck. this site is great and has allways helped me out but im stumped on this one.any help would be great! thanks guys keep up the good work Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 4m 28d Posted 24/05/12 09:10 PM Share Posted 24/05/12 09:10 PM Could be your tps playing up? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 5d Gender: Male Posted 24/05/12 09:13 PM Share Posted 24/05/12 09:13 PM Tell us what codes its got with your flash box Link to comment Share on other sites More sharing options...
chris_richo Member 8 Member For: 14y 4m 27d Gender: Male Location: port macquarie Posted 25/05/12 05:49 AM Author Share Posted 25/05/12 05:49 AM no codes are showing up, I also reloaded my tune and it didnt change a thing. if it is TPS would it show codes? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 5d Gender: Male Location: @ my laptop Posted 25/05/12 05:52 AM Share Posted 25/05/12 05:52 AM there may be codes and your x3 does not pick them up Link to comment Share on other sites More sharing options...
chris_richo Member 8 Member For: 14y 4m 27d Gender: Male Location: port macquarie Posted 25/05/12 06:04 AM Author Share Posted 25/05/12 06:04 AM dam it! my tuner is 3 hrs away and I cant get time off work. might just go buy a TPS form ford, they want $198 though. I was gona try one any way. ill let ya all know how it goes.thanks guys Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 14d Gender: Male Location: Auckland, New Zealand Posted 25/05/12 07:44 AM Share Posted 25/05/12 07:44 AM (edited) Sounds like an expensive way to trouble shoot....$99 on fleabayIf you are going to ford anyway just say you will buy one if they check your codes and it's faulty.If it's not just pay for the scan or buy the faulty part. Edited 25/05/12 07:49 AM by riptide Link to comment Share on other sites More sharing options...
