Does Higher Actuator Give Better Top End ?
FPVF6355
  • Member For: 14y 1m 22d
Hi,
I have a tune to 288RWKW. stock actuator, and the torque kicks in hard around 3000 to 3500 rpm, then dies as the waste gate opens (about 15psi on the tune sheet)
I want to know if a 12PSI actuator will help it hold boost (torque) at higher rpm.
I presume more torque (boost) up high won't be any harder on the motor than lots of torque down in low revs.
or would the result of a higher PSI actuator, increase low down torque too much, and stress the engine ?
Thanks.
  • Member For: 16y 11m 20d
Your boost will be falling away with stock actuator, fit a 12 (or whichever your tuner recommends) port the waste gate and get a retune.
  • Special needs member.
  • Bronze Donating Members
  • Member For: 14y 6m 6d
:stupid: A 12psi actuator won't make a difference down low but it will help hold boost all the way to redline.
thanks that's what I was hoping for.
Why does the waste gate need to be bigger ?
Is there potential to over boost ? and a need to safely relieve a higher volume of air quicker,
How critical is the waste gate size to the actuator PSI opening pressure ?
I'd prefer to do the mods myself, then get it tuned. I have my own machine shop, just want to get it right.
Has more to do with exhaust flow than actuator size I think. A more free flowing exhaust will create more spool and overboost if the wastegate isn't ported to compensate.
