NobleXR6 Donating Members 5 Member For: 12y 9m 2d Gender: Male Location: Noble Park Posted 23/05/12 08:14 AM Share Posted 23/05/12 08:14 AM Hi Couple of weeks ago while stopping a set of light my ute 09 XR6T start to stall then on the dash up came ETC once I stopped. When I tried to move to the side of the road I couldn't. Ute had lost all power. Turned it off and back on and it was fine for around 20k's when I had to stop at another set of lights. Did the same thing turn off then back on and have not had an issue since until today. Twice the ETC light cam up in around 2k's. Has anyone else had this problem? And if so set me in the right direction. Ute is getting tuned next week so hoping to fix this prior. Cheers Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 5d Gender: Male Posted 23/05/12 08:20 AM Share Posted 23/05/12 08:20 AM Test your battery, also check what tps is on it, old style is triangle shaped ( had problems) new style is a rectangle with one curved side Link to comment Share on other sites More sharing options...
NobleXR6 Donating Members 5 Member For: 12y 9m 2d Gender: Male Location: Noble Park Posted 23/05/12 08:28 AM Author Share Posted 23/05/12 08:28 AM Cheers will look Link to comment Share on other sites More sharing options...
dastard1 Member 42 Member For: 12y 10m 18d Gender: Male Location: briz Posted 25/05/12 05:40 AM Share Posted 25/05/12 05:40 AM ive had very similar problems, we replaced the coils , plugs , fuel filter and I had it retuned cause we crnacked up the boost and it was perfect, for a few days :Z then all of a sudden while driving the car started running ruff as guts! no power and shaking etc, I turned it off and tunrned it on and it sat there running horid but if u turned it on with your foot on the gas it ran ok but then u take your foot off and it goes to idle but cant and starts choking and ruff again ! I cleaned the throtle body and diconected the bat for 10min and it has been fine but has done what u mentioned again since , I am changing the tps in hope that's the problem , and the current one on mine is the rounded shape but im replacing it any way :beta: Link to comment Share on other sites More sharing options...
NobleXR6 Donating Members 5 Member For: 12y 9m 2d Gender: Male Location: Noble Park Posted 13/06/12 02:16 AM Author Share Posted 13/06/12 02:16 AM Cheers Mate. I have just tried turning the key on but not starting the engine then pushing the foot down full and let if off the turn key off. I have not had the problem since but still have a idle issue some time. The ute is going in for a tune soon so I hope they may fine the problem. Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 6m Gender: Male Location: South West QLD Posted 13/06/12 02:49 AM Share Posted 13/06/12 02:49 AM THrottle position sensor, Throttle Pedal Position Sensor, Throttle Body electronic motor drive or a Battery on its way out..Those are the places I'd be starting.. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 9d Gender: Male Location: Perth Posted 13/06/12 04:19 AM Share Posted 13/06/12 04:19 AM diff bush is U\S 1 Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 5m 14d Gender: Male Location: Broady, Melbourne Posted 13/06/12 05:06 AM Share Posted 13/06/12 05:06 AM I had a throtle system problem that went on for few months. It would intermittently limit RPM then shut down the engine. Mine was resolved by disconnecting the TB/TPS, spraying it with some WD40 and reconnecting. The problem hasn't come back for a couple of months now. I don't know if it was just a co-incidence but it hasn't come back since. Link to comment Share on other sites More sharing options...
Mvour.au Member 15 Member For: 15y 6m 23d Gender: Male Location: Gold Coast Posted 15/06/12 08:43 PM Share Posted 15/06/12 08:43 PM I had the same problem that dastard is having on my 06 bf1 xr6t, ended up changing the TPS and it fixed it. Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 5m 21d Gender: Male Posted 15/06/12 09:53 PM Share Posted 15/06/12 09:53 PM ^ +1Before I can select gears I must rev the engine or else the tps has a fit and car runs like crap. Link to comment Share on other sites More sharing options...
