  • GONE FULL WIZARD
  • Member For: 16y 5m 19d
Same thing happens to my F6 Tonez, replaced PCV valve no cure, resorted to using a cable tie to stop the dip stick coming out but mine has always suffered from excess oil usage (catch can in place to stop intake getting filled with oil), I'm just assuming somethings wrong with a piston or ring, engine seems to run fine though and no rattles.
  • Italian Stig!!
  • Member For: 14y 4m 29d
  On 23/05/2012 at 5:36 AM, Paulie2256 said:
Did you check the breather for blockage as mentioned?
yer I did Paulie, breather checked, PVC checked taken a part all clean and works fine.
  On 23/05/2012 at 5:40 AM, PAZZOnegger said:
Tonez just build a new motor and be done.
easy to say pazzo lol, not ready to do that, or get a fg, but still love my bf
really man, yer no rattles in mine and runs fine, been leak tested and came good, do still got your F6 man??
  • Member For: 14y 5m 7d
You could take the valve out of the cam cover and try blowing down it. On boost it will be blocked anyway won't it? as the intake manifold pressure closes the line check valve.
You could fit a catch can with a breather before the check valve in the line, similar to this but with a breather. But you would only be treating the symptom, not the cause.
post-44395-0-16575800-1337753146_thumb.j
  • GONE FULL WIZARD
Yeah Tonez still have the F6 and the dipstick is still cable tied :)
  • Like 2
  • Member For: 14y 8m 3d
Tonez this is what you do before wasting a heap of cash
1 - Take car to tuner
2 -Remove performance products
3 - put back all stock parts if you have them
4 - load stock tune
5 - take to dealer and trade in
6 -drive out in a Fg
  • Like 2
  • Member For: 17y 3m 5d
I said that ten minutes ago on Facebook. But I threw in a heap more racial stereotypes.
