  • Italian Stig!!
  • Member For: 14y 4m 30d
Hi guys
Wanted to know if anyone can help me!!! what cause this to happen >>>>>
I have a bf Xr6 turbo, I have recently service done, change the oil and the filter in the car.
I have notice that the dip stick keeps popping up past the o ring, and oil squirting out everywhere, it seems to happen when put foot down building up boost.
Just recently I got crank case pressure tested! and results were excellent, no piston rings are gone, I have check the breather hose that goes to the intake and its working fine no oil in the line as well and spark plugs are fine nice and clean to.
At the moment I am completely stuck, not sure whats the problem :(
Cheers.
  • Moar Powar Babeh
  • Member For: 19y 9m 3d
Check you pcv and the small one way valve in the pcv line. Also how does the oring on the .dip stock look? Its it worn?
  • Bronze Donating Members
  • Member For: 13y 10m 30d
Crankcase is pressurising... Head gasket? Head cracked? Cylinder cracked? Pcv valve broken? Valve Stem seals leaking?
  • Member For: 19y 30d
You have to be getting some pressure from somewhere for the dip stick to lift and the oil to come out at that point, either you have too much blow buy or the turbo is pressuirizing the crankcase some how, how was your car checked?
