Fuel Rail
  • Member For: 13y 6m 27d
Just wondering I removed my fuel rail & injectors because I made a mistake while installing such a simple surge tank :/ now the car won't start.... How long should it take to start after emptying the rail? 6 hours to install a 30m job FML!
Yeah a pw tank! I can hear both pumps priming. I installed the wring kit connecting the pink wire!
What switch may have I triggered?
Edited by Kosij
That's why it took me so long to install! I plugged the wrong hose into the rail! Couldn't unplug it so I had to remove the rail to unplug it.
So I'm 99% certain the pump is going to rail!
Will double check in the morning. Could a small leak cause it?
Edited by Kosij
  • Member For: 14y 5m 17d
All the injectors are plugged in correctly? It should start after about 10 seconds if that. Something been done wrong. If you bypass the new surge and plug the lines back in where they should go does it start?
