Just Tuned, Making Half The Boost!
188ite
  • Replies 38
  • Special needs member.
  • Bronze Donating Members
  • Member For: 14y 4m 2d
^^Could try RDP in redcliffe. Also heard Matty Spry is pretty good all round just not sure what he's like with xr6t's. Hear a lot of mixed stories about Chip-Torque and Hi-Torque.
  • Menace
  • Member For: 13y 8m 18d
It was left there for the whole day while I was at work, but after I let it warm up after a couple of minutes of driving, it was already playing up.
Where do you get t bolts from?
I checked my DTC's and its coming up with 3 codes P0172 system too rich P1131 sensor indicates lean P1132 sensor indicates rich. I aint driving this thing on boost at all now
I didnt buy these 1's, this is just a quick search, but this is what they look like.
http://www.ebay.com.au/itm/4-STAINLESS-STEEL-T-BOLT-CLAMPS-3-HOSE-79-87MM-/300706965301?pt=AU_Car_Parts_Accessories&hash=item4603882735
You can buy them from auto stores though they usually charge abit more something like 7 or 8 bux each I think, probly more.
TBH I cant really remember where I got mine from probly fleabay, but they do the trick and are sh*t loads better than your usual hose clamps.
You need to get like a 100mm clamp for the throttle body join if I remember correctly... might wanna double check the size for that 1.
  • blind leading the blind
  • Member For: 16y 3m 28d
I'm not rubbishing them, but I'm worried if I send it back to them, something will happen, costing me huge dollars.
And plus Ace, where else is there to go in brisbane/gold coast?
mate there is elite automotive, rdp, fpt in toowoomba, but im sure kent will sort you out. could be wrong though
Check all your I/C piping thoroughly before you take it back. No point in paying someone else to do something you can do yourself. As others have said the most common one to slip off is the one on the throttle body. Run your hand around underneath it as it may have come off or split and you wont even see it. May also help to get someone to give it a bit of a rev while you listen/feel around all your piping.
  • 8 months later...
