THCOOK Member 58 Member For: 15y 5m 18d Gender: Male Location: sydney Posted 15/05/12 08:30 AM Share Posted 15/05/12 08:30 AM There are a few guys on ebay selling flip keys as any one tryed them do they work what has to be done for them to work? 1 Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 13y 11m 16d Posted 15/05/12 09:17 AM Share Posted 15/05/12 09:17 AM needs to be cut, program keypad to car (in owners manual), and program the key itself so it will disarm the immobilizer (can be done at ford, or instructions are on here, somewhere).The seller might have instructions? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 7d Gender: Male Location: Christchurch, New Zealand Posted 15/05/12 10:56 AM Share Posted 15/05/12 10:56 AM (edited) I have one for my ute.You need to make sure you get the right key for your model. So BA has one type BF has another and FG has another etc.Program instructions are in the owners manual. (do you have your manual). You must get timing pretty right to get the car to enter the programming mode.And to program yourself easily you require 2 currently programed keys.1, So basically buy the flip key, then get it cut at decent key cutter.2, Go to the car and do the programming of the new keys transponder. This envolves something like putting 1st original key in turn to postion 1 remove and quickly put second key in to position 2 remove then put new key in and put in position 2 and allow car to do program which will be indicated by the door locks cycling I believe. (its got clear instructions in manual)3, Now go on to programming the alarm side of the keys, you push some buttons on the icc while doing something else to enter the programming mode then you must press the door lock button on every remote that you want to use (this includes already programmed ones, if you dont the other remotes are forgotten by the system, this is also a way to stop a remote working should you lose one.)Then your all done, can get the instructions for you if need be.As a note I found my key was cut quite tight so it took alot of force to get the key out of the barrel after the first use. (almost thought the bugger was suck in the barrel) After a couple days it had worn in nicely.You should end up with a nice flip key. Enjoy. Edited 15/05/12 11:01 AM by Wenier 1 Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 4m 4d Gender: Male Location: Melbourne, VIC Posted 15/05/12 11:16 AM Share Posted 15/05/12 11:16 AM Wenier is on the money.. Just make sure its to suit a BA and get it cut properly is all I can add.. Link to comment Share on other sites More sharing options...
THCOOK Member 58 Member For: 15y 5m 18d Gender: Male Location: sydney Posted 16/05/12 04:31 AM Author Share Posted 16/05/12 04:31 AM Thanks guys much appreciated... Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 7d Gender: Male Location: Christchurch, New Zealand Posted 16/05/12 04:53 AM Share Posted 16/05/12 04:53 AM Do you have your owners manual otherwise ill scan mine even thou its a BF procedure should be same. Link to comment Share on other sites More sharing options...
THCOOK Member 58 Member For: 15y 5m 18d Gender: Male Location: sydney Posted 03/06/12 12:11 AM Author Share Posted 03/06/12 12:11 AM thanxs mate I do have my owners manual and ill go through it to programme the key .Thanx again for our help.. Link to comment Share on other sites More sharing options...
THCOOK Member 58 Member For: 15y 5m 18d Gender: Male Location: sydney Posted 05/06/12 12:24 PM Author Share Posted 05/06/12 12:24 PM Received my key had it cut and then programmed it works fine much better than original key. Link to comment Share on other sites More sharing options...
hotxr8 Member 49 Member For: 14y 2m 10d Gender: Male Posted 05/06/12 08:00 PM Share Posted 05/06/12 08:00 PM Who did you buy it from?? Link to comment Share on other sites More sharing options...
THCOOK Member 58 Member For: 15y 5m 18d Gender: Male Location: sydney Posted 06/06/12 05:29 AM Author Share Posted 06/06/12 05:29 AM a guy on ebay Ford Transponder Remote & Flip Key Suit Model BA Falcon FPV XR6 & SX Territory (170827311350) Link to comment Share on other sites More sharing options...
