30Psi+ Map Sensor
stee3
  • Member For: 13y 8m 16d
LOL na I didnt use the any SCT value files. Had to return the software to the workshop today as they needed to tune a car plus its going up on the hoist so I can fit the Super Comp Turbo 400 next week. Im having a small issue with idle ill need to sort out, in the software desired idle in neutral is 900rpm but on the data logger its showing desired as 1000rpm. As you can see by the vid its idling at 1000rpm in neutral. I think I know what the issue is It just comes down to having the time to do it. Thanks for the tip on datalogging for the 4bar map sensor, ill start datalogging after I fit the auto.
  • Member For: 19y 8m 5d
Sweet, the sct files are still set at 39.15psid whereas the website data is now 58 so that's good!
Log your coolant temp as you might have an adder still active? I think the adder for coolant temp goes to zero at 170 degrees F on the BA. BF is oil temp based rather than coolant I think.
