Gtx3582R Vs Dlm Stage 1 Precision Turbo
stevanford
  • Member For: 15y 3m 27d
what car do you have?
what other mods do you have planned?
have you priced everythin you will need to fit either of these turbos?
  • Member For: 13y 21d
Plan on running:
Plazmaman 800hp or 1000hp cooler
4 Inch turbo side intake
ID 1000s
PW or Plazmaman surge tank + 044
Intank pump if needed
Valve springs
Complete exhaust
12psi Actuator
In a G6ET. Two turbos are fairly evenly priced (GTX is slightly cheaper)
  • Member For: 13y 4m 10d
I'm stuck in between these two turbochargers and I'm not sure which I should go for. What would you do and why ?
Not sure if this may help price wise , just got a new GTX3582r with new genuine garrett turbine housing ( not included with the GTX ) ported and flapper mod , with a new 8psi actuator and bracket all assembled for $2600.
  • Member For: 13y 11m 6d
I'm interested in the two as well. Is the precision turbo setup that utilizes the factory waste gate or the one that runs an external gate you's are talking about?
Somewhere on the DLM site they say they have a replacement that uses the factory internal waste gate but its still under development. I was hoping its finished :)
If its the one that uses the external gate and the prices are similar I'd go the DLM turbo kit. They have a variety of turbos that can fit in these kits depending on your application and the external gate provides better boost control.
Edited by knoles
  • Member For: 18y 8m 27d
I was at dlm last week and saw the precision with ext gate set up,it's a very cool set up that will perform very well!
The best thing about the kit is the ability to run higher boost down the track if someone was to build they're engine as the perform better the more boost you put in them!! And who doesn't love an external gate set up!!
Cheers lee
