underoath123 Donating Members 63 Member For: 13y 2m Gender: Male Location: SOR Perth Posted 22/05/12 01:14 PM Share Posted 22/05/12 01:14 PM Pretty sure my system has been set up properly, had the guy do many systems for me, got standard fg headunit PDX 5 M100 mono 2 12inch type r slim subs type r speakers all round and custom mounted tweaters.would add more but not enough room in the ute:/. owell still get quite a nice back massage from the slims hehe:). Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241521 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 4d Gender: Male Location: Melbourne Posted 23/05/12 02:50 AM Share Posted 23/05/12 02:50 AM Parkway kicks would sound pretty savage through those, good stuff.Same way I fixed the problem, Caliban works well too.. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241699 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 8d Gender: Male Location: Wollongong Posted 23/05/12 03:10 AM Share Posted 23/05/12 03:10 AM The only thing that could keep up with parkway would be an 8 or a verrryyyy well built sealed 10... But it sounds so good when set up correctly! Ground loops can also be a common cause, if it's not sourcing Fromm the icc itself. Try to ground everything at one point to minimize risk of ground loops. But unless you have some crazy standard head unit or a good aftermarket one there will always be a level of noise. Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241707 Share on other sites More sharing options...
Guest XR09 Guests Posted 23/05/12 04:14 AM Share Posted 23/05/12 04:14 AM (edited) I was told the alpine processor would remove most of the hiss that the std head unit has. He said he tunes them for the car and installation. Said It would also improve what little range the std head unit has. And I think he wanted all of $800 squid for it set up.So do we have a yeah or a neh on removing the std earth hiss, well that's what it sounds likeps Audioengine speakers are the ducks guts Edited 23/05/12 04:15 AM by XR09 Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241748 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 26d Gender: Male Location: Townsville Posted 23/05/12 08:42 AM Share Posted 23/05/12 08:42 AM I'd say no you wont get rid of it. I have a BA and have isolated mine down to the ICC itself. The induced noise I get is from the actual ICC unit (noisey electronics!). I found this by redoing every earth in the car when I had no factory stereo speakers or the amp connected. I did double earthing, earthing from the alternator, I did fcking everything!!!I did find that disconnecting the rear demister wires and FM cable from the black box in the rear passenger side hood lining does cut down the noise but I think all it actually did was change the nose frequency to a higher pitch that I may be slightly deafer at?My last ditch attempt will be to install 2x 40 amp filters that I got for like $2 each ($30-$40 items) from the WOW sight and sound closing down sale and will remove the ICC and try to figure out where I can input them...Its a deadset nightmare mate and all I can say is good luck! Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241909 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 26d Gender: Male Location: Muswellbrook,NSW Posted 23/05/12 09:01 AM Share Posted 23/05/12 09:01 AM on 0 volume the ICC mutes the audio output IC , im thinking in this case the noise is being induced further down the line , Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1241946 Share on other sites More sharing options...
sam_rigger Member 246 Member For: 14y 3m 15d Posted 23/05/12 10:33 AM Share Posted 23/05/12 10:33 AM well even on my stock ICC with no aftermarket gear installed, there is noise on volume level 1, so I think it's the ICC putitng out the noise, not the gear after it. I'm no expert, just stating my experience in my own car. Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1242053 Share on other sites More sharing options...
sam_rigger Member 246 Member For: 14y 3m 15d Posted 23/05/12 10:42 AM Share Posted 23/05/12 10:42 AM I think I'm gonna get a head unit installed instead. The LC-6 doesn't do what I expected it would do. Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1242071 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 8d Gender: Male Location: Wollongong Posted 23/05/12 10:58 AM Share Posted 23/05/12 10:58 AM You will find with a good aftermarket head unit it will do wonders. You can't cover sh*t in sugar and expect it to be a lamington. Hahahaha 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1242097 Share on other sites More sharing options...
underoath123 Donating Members 63 Member For: 13y 2m Gender: Male Location: SOR Perth Posted 23/05/12 12:17 PM Share Posted 23/05/12 12:17 PM (edited) how do you go about putting a aftermarket deck in a fg, considering the screen and other components I heard a rumor the screen will no longer function as required? could be completely wrong though. can anyone shed some light on this please. o and in my last car with similiar gear I had a 900 dollar aftermarket deck and still had the hiss. Edited 23/05/12 12:20 PM by underoath123 Link to comment https://www.fordxr6turbo.com/forum/topic/80045-fg-audio-upgrade-issues/page/2/#findComment-1242152 Share on other sites More sharing options...
