Washer Jets - No Response
4DZILR
  • Member For: 15y 7d
Which fuse is it for the washer jet motor?? Is there a fuse?? Or is it part of the WS fuse for the wipers??
I am not gettin no noise or response from the washer motor
  • Resident idiot.
  • Member For: 14y 4m 22d
I have found they sometimes stop working for no reason, come back on next time I start the car?! Happens in both cars so must be something in the design.
  • Member For: 13y 10m 6d
It's not uncommon for the pump to fail. Easy fix.
Should simply twist and pull the old one out and reverse procedure to get the new one in. Plug it in again and your done.
I haven't done one in a falcon yet but they usually aren't more than a $30 part.
Check that it's getting power first though.
  • Moar Powar Babeh
  • Member For: 19y 4m 19d
My jets have failed to function twice. Both time is was a build up of algae on the pump inlet.
If yours is the same the best bet is to remove the bottle and flush it with bleach.
  • 2 weeks later...
  • Member For: 14y 10m 14d
noob question alert.
I can hear the motor when I attempt to use the washers, hose is connected - were/how do I get to the bottle/motor
oh BF model.
Edited by -VT-
