Fg Ute Lowering Blocks
stroller
  • SHLAMBD.
  • Member For: 12y 8m 15d
Thought I should make a seperate thread for this question...
Put a set of 1.5 inch blocks in my 2010 FG ute today. however im not sure if they are the correct ones. they fit sweet but just dont look right?
heres some pictures...
thoughts?
Edited by Mitch Lamb
  • Member For: 15y 3d
the leaves are already reset 3 inches. but do those blocks look right?
Really, wow. Is the car even off the ground. Why so low?
They do look right, and as above trim bolts.
what exactly are the lowering blocks ment to achieve
They do exactly what they are called which is lower Shiz. If you look at the pic youll see the block shifts the diff even further away from the leafs which makes the thing lower.
