Capa Ford Flash 2
George2617
  • New Member
  • Member For: 13y 11m 17d
HI guys,
I just bought a CAPA flash tuner 2 and I'm just trying to find other peoples settings they have put into the vehicle. I have a BF XR6T.
The settings I can change are:
Fuel Adjustment
Spark Adjustment
Adjust Rev Cut / Limit
Fuel Injector Size Selection
Idle RPM Speed
Boost Adjustment for Turbo Cars
Automatic Transmission Shift Firmness
Cooling Fan Temperature Adjust
Read / Clear OBD-II Trouble Codes
Diff gear change
I want to get the fastest I can but not too much stress on the engine.
Cheers
George
  • Member For: 16y 2m 23d
My diff settings are 3.73:1 because didn't like the stock 2.73:1
boost is turned up to 1300W
Spark plugs are set to 2.4jigawatts
Injectors are set to 4000cc (gets a bit thirsty with this setting)
I have a manual but changed the shift firmness up all the way and it now spins the tyres during gear change
Took the rev cut out too.
Hope this helps
Edited by Paulie2256
  • Like 2
  • Member For: 18y 8m 17d
Does anybody read the warnings about running generic tunes anymore?
To the OP, running a generic tune can lead to problems, why adjust things if you do not know where they are to at present, it may lead to expensive issues?
I would suggest you get a custom tune, but the bad news is the flash box you have purchased can not be used by another tuner to tune your car.
  • Like 2
  • Turboless
That's why you usually research stuff that does cost a fair whack..and so important to an engine in particular. Cost being any consequences in the future. Like engine go boom boom
  • Member For: 14y 1m 25d
Mate, as ratter said, leave it all well enough alone. The old saying about not touching things you don't understand really applies here...
You need to go and get a custom tune and the tuner will know how to change all that stuff.
It's not locked out, but any car that has ZF will have a tune file that the Xcal 2 can not work with, so basically any BF/FG auto will not be able to use a flash 2
except they can not use the Xcal 2, actually there may still be a couple of BF processor codes that may not have ZF data, not sure if they have all been covered yet, if the OP had a processor strategy that did not support ZF, then a tuner could still use the Xcal 2
