WhiteXR Member 117 Member For: 14y 1m 20d Gender: Male Location: sydney Posted 01/05/12 12:05 AM Author Share Posted 01/05/12 12:05 AM Fix the turbo. If you keep running it with the faulty turbo you are risking even more damage or even complete failure. Leave the manifold for now and get the turbo rebuilt.Throwing more expensive parts at it wont fix it. If the tuner just keeps taking your cash then he sure is taking you for a nice ride. Its to late for me to leave the manifold, since I have already bought it. When I go to put it on, il be sending the turbo back to get it checked since it is a brand new garrett with 12 months warranty. Link to comment Share on other sites More sharing options...
daztbo FLY-FPV Donating Members 474 Member For: 15y 4m 4d Gender: Male Location: Greensborough Vic Posted 01/05/12 12:12 AM Share Posted 01/05/12 12:12 AM Yeah my tuner said he tried everything and he started blaming the way I've installed the mods so I said shutup and change the computer and they put a spare one in they had laying around and bang fixed it they said that half the computer wasn't working properly so it would run fine but once you started putting boost and timing into it it started freaking out and doin what it wanted lol chuck a second hand PCM in see if it makes a difference Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 14y 1m 20d Gender: Male Location: sydney Posted 01/05/12 12:17 AM Author Share Posted 01/05/12 12:17 AM Yeah my tuner said he tried everything and he started blaming the way I've installed the mods so I said shutup and change the computer and they put a spare one in they had laying around and bang fixed it they said that half the computer wasn't working properly so it would run fine but once you started putting boost and timing into it it started freaking out and doin what it wanted lol chuck a second hand PCM in see if it makes a difference Mate I have this gut feeling all the time that its got something to do with the computer,so il for sure let the tuner know about this, thanks for your help mate. Link to comment Share on other sites More sharing options...
daztbo FLY-FPV Donating Members 474 Member For: 15y 4m 4d Gender: Male Location: Greensborough Vic Posted 01/05/12 12:24 AM Share Posted 01/05/12 12:24 AM All good mate hope ya sort it out let me no when ya do Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 14y 1m 20d Gender: Male Location: sydney Posted 01/05/12 12:24 AM Author Share Posted 01/05/12 12:24 AM (edited) Yeah like most have said, change tuner. What state you in? Im from nsw sydney mate, il let the tuner try an sort this out one more time, an if he cant then I guess il be seeing a new tuner, other then that the tuner im using now has been good to me, an has help me heaps. Edited 01/05/12 12:26 AM by WhiteXR Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 14y 1m 20d Gender: Male Location: sydney Posted 01/05/12 12:27 AM Author Share Posted 01/05/12 12:27 AM (edited) All good mate hope ya sort it out let me no when ya do No probz mate I will. Edited 01/05/12 12:27 AM by WhiteXR Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 5d Gender: Male Location: @ my laptop Posted 01/05/12 12:50 AM Share Posted 01/05/12 12:50 AM You can not just swap ecu's, they have to be programmed.What software is being used, do you know?Has data logging been performed to see what is actually happening? 1 Link to comment Share on other sites More sharing options...
SPOOLAX Skids? Donating Members 975 Member For: 15y 6m 25d Gender: Male Location: Adelaide Posted 01/05/12 01:36 AM Share Posted 01/05/12 01:36 AM You can not just swap ecu's, they have to be programmed.What software is being used, do you know?Has data logging been performed to see what is actually happening? Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 14y 1m 20d Gender: Male Location: sydney Posted 01/05/12 01:40 AM Author Share Posted 01/05/12 01:40 AM (edited) You can not just swap ecu's, they have to be programmed.What software is being used, do you know?Has data logging been performed to see what is actually happening?Hi mate im using an xcal 2 for my car, data logging has been performed earlier on when I was complaining about boost being all over the place, from 19 psi to 5psi an then back an forward, now that issue has been sorted, I think he said it was tourqe tags an something also to do with spark tables being all over the place. Now I dont know if this would have anything to do with me not making power but I seem to have two other issues first one is air temps on his dyno starting at 27 celius an then at end of run ending at 47 celius, im not sure if that's really that bad, I presume its because of lots of boost being used an that's why its high,(by the way I am using a brand new plazmaman 1100 intercooler) tuner at first thought it was my other intercooler causing high temps, but putting on the new plazmaman cooler didnt do much of a difference except to make the turbo spool sooner.Now my second problem, iv always complained about my car running to hot even at low cruising speeds an on idle, water temps on my new obd gauge reads at 97 celius an up to 103 celius an that's in this cold weather as well. Tuner then put in a 71celius or something like that thermostat in an my temps are still the same, except when im cruising at about 80klm an over it will reach 76 celius, which I think isnt right, an I think now when I try an give it hits at this temp, it starts to miss while at wot.Pretty much I can remember the tuner telling me that timing keeps getting pulled out while my car was on the dyno. Edited 01/05/12 01:50 AM by WhiteXR Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 1m 10d Gender: Male Posted 01/05/12 01:41 AM Share Posted 01/05/12 01:41 AM Intune motorsports? 1 Link to comment Share on other sites More sharing options...
