pkaboo Member 38 Member For: 19y 3m 29d Posted 30/04/12 10:54 AM Share Posted 30/04/12 10:54 AM (edited) Hey guys,I recently had my car run up on the dyno to check the power level and was quite suprised at the result....The car is an FG XR6T 6spd auto with Rapid Systems intake pipe and XR8 airbox as the only mods, which are both proven to add little to no power.256rwkw at 9.5psi in 3rd gear on Graham West Dyno in Adelaide. Brett was very shocked at the result and said that most FG's that he gets through make around 220.... He also went as far to say that he thought the car was tuned, as he said that tuned FG's are only putting out between 260 and 270 on his dyno. AFR's were 13 coming on boost, 12 through most of the rev range and dropping to 11.5 at 5700rpm.The inlet temp was 31 degrees at 2260rpm rising to 50 degrees at 5580, which I assume would be expected with the standard cooler??!The concerning part for me is the injector duty cycle, as it hits 100% at 4300rpm and continues like that till redline. Is this an issue? It seems like an issue! Brett said it's ok providing I don't get a sh*t batch of fuel or something, and even then, it MAY not cause an issue...Cheers Edited 30/04/12 10:55 AM by pkaboo Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 1m 5d Gender: Male Posted 30/04/12 11:01 AM Share Posted 30/04/12 11:01 AM Most make 15-20rwkw more in 3rd than they do in 4thOther than that is the car 2nd hand? Could have had a tune at some stage Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 1m 5d Gender: Male Posted 30/04/12 11:02 AM Share Posted 30/04/12 11:02 AM Ohh just saw your in adelaideThey put something inthe water over there, it will make 238rwkw in 4th like every other car if dynoed in VIC 3 Link to comment Share on other sites More sharing options...
pkaboo Member 38 Member For: 19y 3m 29d Posted 30/04/12 11:04 AM Author Share Posted 30/04/12 11:04 AM Purchased as a demo from Ford with 2000kmI get what you're saying about 3rd gear being higher, but I'm comparing directly with other stock Fg's and tuned ones on the same dyno in the same gear.... Link to comment Share on other sites More sharing options...
pkaboo Member 38 Member For: 19y 3m 29d Posted 30/04/12 11:07 AM Author Share Posted 30/04/12 11:07 AM The number itself means f*ck all to me, I'm more concerned about the injector duty cycle. I'm still surprised at the number it's making in comparison to others on the same dyno though !!! Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 25d Gender: Male Location: @ my laptop Posted 30/04/12 11:10 AM Share Posted 30/04/12 11:10 AM It's not unusual for FG's to max the injectors with the stock tune Link to comment Share on other sites More sharing options...
pkaboo Member 38 Member For: 19y 3m 29d Posted 30/04/12 11:24 AM Author Share Posted 30/04/12 11:24 AM So it's not something I need to be overly concerned about??? Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 3m 27d Gender: Male Location: Far north queensland Posted 30/04/12 08:51 PM Share Posted 30/04/12 08:51 PM I would be concerned about the duty cycle - afr's up top seem like it isn't leaning out so that's a good thinggood enough reason to get a cat, cooler/piping, injectors and a tune Link to comment Share on other sites More sharing options...
pkaboo Member 38 Member For: 19y 3m 29d Posted 01/05/12 11:37 AM Author Share Posted 01/05/12 11:37 AM What power figure would that get me to.....Roughly Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 2m 2d Gender: Male Location: Parramatta, NSW Posted 01/05/12 01:14 PM Share Posted 01/05/12 01:14 PM 300 or thereabouts. Link to comment Share on other sites More sharing options...
