  • Member For: 17y 2m 16d
Because Danny's to slow.
  • RNS10S
  • Member For: 18y 9m 20d
Torque gets you off the line, power keeps you going and by the looking at the dyno sheet I can certainly see you have enough of both.
I love how it keeps making power, even at 180 klms.
Change your sig to 480rwkw+++++++++++......lol
  • Member For: 19y 9m 25d
Lol. Yeah, I Done this e85 tune last sep, adjusted it a little for united e85 as it tested to be more like e90. Single change in the PCM to adjust that.
I kept it at 18psi, but wanted more psi up top to keep the torque line like a table top but unfortunatly I've only got a 7psi spring in my gate and I'm controlling boost by bleeding off the bottom port only (nothing connected to top port). As that's how the ford PCM controls boost by bleeding off. I will however hook the gate up properly and correct the boost control in the PCM so it operates in reverse. Hopefully then get more boost upto.
Thanks mick. The broken diff bolt kept me off the road the longest. Lol but once I fixed it I had a mission :)
I remember when you ran your 10.80 with 3.7 gears. You must have been turning at least 6500rpm crossing the line back then yes?
Either way. Blue boost ran a 9 on stock engine, c16.. E85 is "nicer" on engines so I might see if I can get a 9 as well once I sort out my tyre/gear ratio problem.
Or might just rise rev limitor to 7000rpm.. Hey mick :). Lol
  • Member For: 19y 4m 28d
Good sh*t brother, my help last sunday must of worked (reading afrs out) while you concentrate on keeping it straight...... hahaha,
Edited by cole trickle
I had the pleasure of seeing this run. Bloody awesome. Congrats.
It was good having a chat with you last night. Congrats on your new PB also.. Cant believe you didnt get warned once out of your 4 or so mid 10 passes. I got warned straight away.
