dedogman Member 52 Member For: 16y 2m 14d Gender: Male Location: Marsden Park, Sydney West Posted 28/04/12 07:20 AM Share Posted 28/04/12 07:20 AM Hi Guys, What would be the most common reason for developing a shake in the front wheels. Had an alignment done a month ago and the mechanic said all good but he is full of crap! Still shakes and today it felt like the bloody wheels were goin g to fall off!I'll book it in on Monday but any suggestions would be a great help....I have the IQ of a brick when it comes to cars and repairs!Thanks in advance.Dedogman Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 5m 15d Gender: Male Location: Perth NOR Posted 28/04/12 08:14 AM Share Posted 28/04/12 08:14 AM You might check this. Common issue of the master brake cylinder lever needing adjustment. Causes the brakes to be slightly appiled with pads rubbing on rotors and causing shudder(if rotors not perfect) especially at higher speeds.I think you can test by jacking up a front wheel and see if it spins easily without any drag. The front brakes/wheels will probably be getting pretty hot too.Someone else might know more of this issue and chip in. My suspension shop was telling me about this. Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 8m 22d Gender: Male Location: Geelong, Victoria Posted 28/04/12 11:25 PM Share Posted 28/04/12 11:25 PM Could be the wheels not sitting flat against the hub. Warped discs. As mentioned the master cylinder Link to comment Share on other sites More sharing options...
Evil XR6T Bronze Donating Members 138 Member For: 13y 2m 1d Gender: Male Location: Townsville Posted 03/05/12 03:48 AM Share Posted 03/05/12 03:48 AM I've also had this issue. Mine was due to warped brake rotors. Ordered new pads and upgraded rotors for under $400 from Auto One, fitted them myself and it reduced dramatically. There was still a little vibration there which I found out later to be that all my rims were buckled. Now I have new rims, car drives beautifully. Link to comment Share on other sites More sharing options...
Bede Donating Members 1 Member For: 13y 3m 7d Gender: Male Location: Sydney Posted 25/05/12 06:18 AM Share Posted 25/05/12 06:18 AM From what I've read, I think everyone who owns a BA has had this problem. Mine used to shake so bad I thought it would come apart at the seams. A new brake booster eventually solved the problem, but the quest for a vibration-free front end has seen me replace 2 sets of rotors, pads, all new front bushes, ball joints, added Boge struts, camber kit - and that's just the front. Drives better than a new one now... Link to comment Share on other sites More sharing options...
JMF Member 8 Member For: 14y 8m 21d Posted 04/10/14 02:29 AM Share Posted 04/10/14 02:29 AM Bede, I know it's been 2 and a bit years since you posted this and we've been having a similar conversation on another thread. If you're still out there, was the new booster a long term fix? I think I'll have to get the lower control arm bushes changed now as have had the car for 4yrs/60,000 kms but the booster seems to be the most common. There's one going on ebay which is internally modified to prevent and in talking to the seller he assures me (don't they always? :-) it will stop the shudder if it's happening when the brakes are not being applied, but it's kinda pricey Link to comment Share on other sites More sharing options...
gregaust Member 48 Member For: 21y 1m 30d Gender: Male Location: QLD Posted 04/10/14 03:09 PM Share Posted 04/10/14 03:09 PM (edited) Seen that booster. Wonder what he has changed other than the pushrod length. Even to the point of getting it apart. They don't twist apart like normal boosters they are crimped together. Edited 04/10/14 03:10 PM by gregaust Link to comment Share on other sites More sharing options...
