Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 27/04/12 09:32 AM Share Posted 27/04/12 09:32 AM Hey fellas well the topic title pretty much sums it up..I fitted a surge tanks to my car almost 2 weeks ago now and the car has been running fine...if anything betta!Under WOT the car has been gr8 only I was told last night by my misses that it blows black smoke..mind you I was pulling 3rds at the time.The car is a BF MK1 with all the bolt on goodies inc. valve springs + port and actuator has been done, it s a manual.Now it just started tonight I noticed under decel the car popping loudly in roughly 0.5-1sec intervals.Probably not the smartest thing to do but I ramped up on the power once at roughly 3/4 throttle, it just started to make boost and started pulling then all of a sudden it felt like traction control was kicking in and almost made me head butt the steering wheel, I jumped off the throttle straight away and limped to work..I am going in next wednesday to get the car checked and tuned for the surge tank install after tonights events.I had been putting off getting it tuned after the surge tank coz im a lazy turd and havent had the time at the moment.Does anyone have any ideas what it could be off the bat..?I realise fingers will point straight at the surge tank install but as I said it has been running beautiful for the last 2 weeks..Thanks guys Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 1m 18d Gender: Male Location: Auckland, New Zealand Posted 27/04/12 09:45 AM Share Posted 27/04/12 09:45 AM I don't recall getting mine tuned after I fitted the surge tank. The regulator should still control the fuel pressure shouldn't it? as long as the supply is good. Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 27/04/12 09:58 AM Author Share Posted 27/04/12 09:58 AM Well that's what I thought too.. in the beginning,hence my lazyness to get it retuned again.TBH the car def. does/did feel stronger though, especially in the mid range not sure about the top end as I would need to check in 4th gear its been ripping 3rds with ease now so its hard to tell if the top end of the rev range is betta or not. Revving 4th out is just asking for trouble IMO. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 1m 18d Gender: Male Location: Auckland, New Zealand Posted 27/04/12 10:04 AM Share Posted 27/04/12 10:04 AM You might need to check your fuel pressure. Maybe there is a problem with the plumbing or the regulator is kaput? Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 27/04/12 10:15 AM Author Share Posted 27/04/12 10:15 AM True.. it makes sense the reg. could be stuffed..That would seem to explain the loud popping on decel. I guess.Just doesnt explain the part where it feels like I've hit a wall under load at around 3K. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 14d Gender: Male Location: SE Melbourne Posted 27/04/12 10:26 AM Share Posted 27/04/12 10:26 AM If the car has been running rich there is a chance you have stuffed your plugs and/or piston rings. Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 27/04/12 10:31 AM Author Share Posted 27/04/12 10:31 AM (edited) doubt it would be the rings tbh with these symptoms.. but plugs yeh maybe they havent been changed since august last year and I dont think they are iridiums.I forgot to mention its taking now roughly 4 turns to start whereas before it would start right up. Edited 27/04/12 10:33 AM by Kroozin Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 14d Gender: Male Location: SE Melbourne Posted 27/04/12 10:44 AM Share Posted 27/04/12 10:44 AM (edited) Sorry I worded that wrong. Not saying your rings are stuffed but running too rich can damage the rings and other components. First things I would be checking in your case are plugs and the cat. Then fuel pressure, AFR and tune adjustment if needed. Edited 27/04/12 10:45 AM by Paulie2256 Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 27/04/12 10:55 AM Author Share Posted 27/04/12 10:55 AM Sounds good. Dumb question but how will I know if the plugs are f*cked? Is the general consensus just relace'em?With the cat can that be checked by banging it by hand underneath and listening for loose sh*t inside?I could most likey borrow my brothers fuel reg and the rest will have to wait till wednesday I guess. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 7m 9d Gender: Male Posted 27/04/12 11:00 AM Share Posted 27/04/12 11:00 AM Coils maybe.... I dont see how installing a surge tank and 044 can make it run richer if the fuel pressure regulator is working properly.... I fitted a surge tank to my bf when it was running 300kwatw and afr's remained exactly as they were Link to comment Share on other sites More sharing options...
