Viper XR50T Member 61 Member For: 14y 4m 5d Posted 27/04/12 06:21 AM Share Posted 27/04/12 06:21 AM (edited) I normally leave the bonnet up when I park my car in my garage to let the heat out.everything has been like clockwork, hadn't had a problem since I bought my car 2 years ago but today I noticed coolant spweing out of the resevoir when I popped my bonnet up and it went on until the res was emptyrang Ford to book it in for a service but just wanted to find out if people have come across this before. I've searched and found some topics but they didn't post back whether they fixed or found the cause of the problemmy car is a 2010 FG XR6 Turbo 50th Ann, done 18K km. its stock apart from an MSCN turbo line filter and the coolant hasn't been replaced since I bought the caralso pics of the coolant in res tank / tank itself. I noticed the coolant going from green to a yellow colour since getting the car and a white residue/mark on the inside of the res today after it finished spewing coolant.can it be simple e.g. the res cap needs replacing? Edited 27/04/12 06:23 AM by Viper XR50T Link to comment Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 16y 6d Gender: Male Location: Victoria Posted 27/04/12 10:32 PM Share Posted 27/04/12 10:32 PM Is the coolant boiling in the bottle? Thermos coming on? So it's shooting out the bottom of the overflow bottle where the overflow hole is? Link to comment Share on other sites More sharing options...
Viper XR50T Member 61 Member For: 14y 4m 5d Posted 28/04/12 01:22 AM Author Share Posted 28/04/12 01:22 AM (edited) Is the coolant boiling in the bottle? Thermos coming on?So it's shooting out the bottom of the overflow bottle where the overflow hole is?yep coolant was definitely boiling in the res, thermos were running for a bit until I turned off the car. I normally let it idle at least 2 minutes before I turn it offthen the coolant starting shooting out the res cap after about 2 mins when I switched the car off. the pressure was coming from the radiator going into the overflow and the coolant in the overflow was boilingdid checks for milky oil (headgasket) but oil was fine was still fresh was just changed on the same day.I waited until the coolant on the ground dried up and checked the hoses for any signs of cracks, leaks, etc, filled the overflow res back up with demineralised water and started her up. the car was running fine coulnd't see any noticeable leaks from any of the hoses?im thinking it might be the thermostat Edited 28/04/12 01:31 AM by Viper XR50T Link to comment Share on other sites More sharing options...
