BF06T Member 8 Member For: 16y 4m 21d Posted 24/04/12 07:31 AM Share Posted 24/04/12 07:31 AM Hi guys, first time I have had to use this site for fixing my own car!! So here goes, my ute all of a sudden lacked power when under load up any sort of incline, or foot flat to the floor, on the flat roads still no boost but can still drive the car comfortably. It had a couple of exhaust manifold bolts loose, so I took the turbo off and manifold and replaced all gaskets. Test drive car still the same. But second time I drove it, engine light came on and I had it checked and the code was for a air intake temp sensor?? Ford told me it was a map sensor so I replaced that, test drive still the same. Engine light on again after a couple of drives.Plugged into a snap on scan tool and the code was wastegate failed to open. Ended up taking the boost solenoid off to see if it was blocked and I could blow through it both ways. Sprayed it with wd and put it back on. (Should it have a ball valve or something inside?? Was quite heavy for a small unit?) Back on the scan tool and no change......*small dent in cat converter(could this be a back pressure problem??)*no exhaust leaks*new map sensor*turbo inlet and exhaust are spinning freely*all hoses are tight and no cracks from what I can see(no noises either)*manifold pressure didn't increase on the scan tool going from idle to flat(no boost)*owned the car since new, always good oil and changed at regular intervals(ex mechanic)*mm not sure what it is...any help would be much appreciated....don't want to give ford mechanics my money!!!Thanks heaps guys!Greg Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/ Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 07:54 AM Share Posted 24/04/12 07:54 AM boost gauge avaliable?if Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226773 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:05 AM Share Posted 24/04/12 08:05 AM try also removing the intake pipe to the tubo , start it up and make sure it spins Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226777 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:06 AM Share Posted 24/04/12 08:06 AM although its making no boost , is it reving ok? Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226780 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:08 AM Share Posted 24/04/12 08:08 AM boost contorller is open at rest , clamps line to increase boost , releases to open wastegate to control boost Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226781 Share on other sites More sharing options...
BF06T Member 8 Member For: 16y 4m 21d Posted 24/04/12 08:14 AM Author Share Posted 24/04/12 08:14 AM Ah no boost gauge available, but on scan tool, pulled up a view of manifold pressure and sitting on just below 100 kpa, which is atmospheric, didn't change a bit when put foot to the floor and a stand still, no boost.No its not revving ok, very slow to even rev at idle. Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226782 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:25 AM Share Posted 24/04/12 08:25 AM pull the intake to the turbo off, check she is spinning, Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226785 Share on other sites More sharing options...
BF06T Member 8 Member For: 16y 4m 21d Posted 24/04/12 08:28 AM Author Share Posted 24/04/12 08:28 AM ok will do, think it will be, u can give it a big rev and turn it off and its still spinning Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226787 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:32 AM Share Posted 24/04/12 08:32 AM does the map value on the scantool vary at all? or is it just around 1 value Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226789 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 29d Gender: Male Location: Muswellbrook,NSW Posted 24/04/12 08:35 AM Share Posted 24/04/12 08:35 AM scan this for mesetup scanner , turn car to reds so its reading values, look at MAP value , now start car , does map value change? , if so how much ? Link to comment https://www.fordxr6turbo.com/forum/topic/79865-issues-with-no-boost-on-a-bf-ute/#findComment-1226790 Share on other sites More sharing options...
