  • Member For: 15y 10m 21d
yep on e85
stock rail is fine and you can either modify the stock reg or wire the fuel pumps up so only one is on at idle and then both on boost
  • Member For: 19y 9m 5d
Or you could buy a blueprinted 4 bar drop in reg which has a MUCH bigger return than the stock Bosch unit. Check out 034Motorsports. The audi gear is very relevant to the Aussie Fords and there's heaps of cool stuff if you use a bit of imagination. .........and yes their regs are fine with e85!
  • Bronze Donating Members
  • Member For: 14y 2m 21d
I was talking to a few people yesterday and they reckon E85 wears your engine a lot faster even a built one is this true?
  • Member For: 16y 4m 22d
E85 burns better, cooler and has a higher octane rating so better for your engine.
98 has additives (at least bp does) that help lubricate and clean as it burns. I wonder if they put similar stuff in pump e85.
