  • Flat out like a lizard drinkin !
  • Member For: 15y 2m 30d
Problems like this have occurred from even standard cars. the likely hood is only greater when your more than doubling the power output.
So the job is done, all up it took around 4 hours the hardest part being reinstalling the box, that I assure you was a *beep* doing it solo.
post-38859-0-58850400-1335366223_thumb.j
after pulling the box out all the bolts where loose and one was completely out lying in the bell housing.
post-38859-0-28989700-1335366241_thumb.j
post-38859-0-58868000-1335366253_thumb.j
there is the converter it was all good with no damage present.
Edited by FIERCE
  • It's All In Your Mind
  • Member For: 21y 5m 19d
I have a bit of an intermittant light squeal coming from around the front of the box, rear of the engine area sometimes when the car is idling. Its only there sometimes and sounds a bit like a squealing belt. Does anybody know if that's a flexplate symptom?
Edited by hypnodoc
  • Member For: 14y 4d
Ive just broken my atomic flexplate, snapped most the bolts off and they were tig welded
I spoke to brad from atomic, and he said he gets them sent off and has a guy do it for him, and its perfectly fine
and it doesnt send your engine out of balance, and the heat from the weld wont weaken the bolts etc..
dont know why it broke then ???
  • Member For: 15y 10m 26d
did it break the bolts or break the weld off the flex plate? welding high tensile bolts etc normally just makes them brittle and then break
have you got an atomic balancer aswell?
Edited by possum
its broke the welds off the plate, and sheered some off from the crank, the welds themself were about 10cm on each bolt, my mechanics rekon the heat has made them brittle.. I have to tap the bolts out the crank, and re tap it with stronger bolts I was suggested
Its got a 998 atomic complete motor
sorry I mean 1cm lol, and snapped the bolts in half off the flexpate or straight off
  • Bronze Donating Members
  • Member For: 13y 8m 21d
  On 21/04/2012 at 8:04 AM, bionicxr6t05 said:
Wow I would not go doing that, apart from balance issues the thermal stress caused by welding can destroy the flexplate under load
