nelsonian101 Donating Members 961 Member For: 16y 7m 15d Gender: Male Location: Sydney Posted 20/04/12 02:24 AM Share Posted 20/04/12 02:24 AM I am using 4 pot Brembos for around 5 laps before they get quite hot. AP Racing Dot 5.1 fluid, always fresh.Using the DBA5000 T3 slotted rotors and Endless PC35 pads.The dust seals burnt out long ago.Saw this pic on a forum somewhere and was wondering if it was that effective?I am already doing a cool down lap or 2 (plus a 100km/h road trip) when at Wakefield.Also using a floor/industrial fan when in the pits that I switch between blowing onto the intercooler/radiator and front wheels.6 pot AP Calipers would be nice but can't justify the expense of even 6 pot Brembos now.Any other ideas? Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 12d Gender: Male Posted 20/04/12 02:28 AM Share Posted 20/04/12 02:28 AM Flexible piping were the spottys are leading to the breaks? Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 8m 16d Gender: Male Posted 20/04/12 02:49 AM Share Posted 20/04/12 02:49 AM Brake ducts are about the only thing I could think of that would help.I just have the PBR upgrades on mine and I never had brake fade but I could only go hard for 3 laps at I time and you obviously brake a lot harder than I do. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 17d Gender: Male Location: Perth Posted 20/04/12 02:50 AM Share Posted 20/04/12 02:50 AM Titanium shims between the pads and pistons to reduce heat transfer Link to comment Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 15y 8m 7d Gender: Male Location: Brisbane Posted 20/04/12 10:53 AM Share Posted 20/04/12 10:53 AM The flap that sticks down from the stone tray underneath cut the section out where it curves up on each side. It will allow air to flow in behind the wheel and will keep your brakes cool. The part to remove is circled in red below. Link to comment Share on other sites More sharing options...
Tim Member 142 Member For: 16y 6m 28d Posted 10/06/12 10:46 PM Share Posted 10/06/12 10:46 PM What about water cooling them. V8 supercars use a mist of water into the air duct for the brakes. The super trucks that I saw racing a few years ago had massive plumes of steam coming off the front wheels. These trucks had a top speed of 180km/h and must have weighed 5 tonnes or more. Link to comment Share on other sites More sharing options...
poida97 Member 124 Member For: 20y 11m 11d Location: Bossley Park, NSW Posted 25/07/12 10:35 AM Share Posted 25/07/12 10:35 AM The flap that sticks down from the stone tray underneath cut the section out where it curves up on each side. It will allow air to flow in behind the wheel and will keep your brakes cool. The part to remove is circled in red below.Hey ScatterBrain, could I trouble you to re-post the pic of the area to cut out of the undertray? It looks like it's not available on imageshack.Thanks,Anthony Link to comment Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 15y 8m 7d Gender: Male Location: Brisbane Posted 26/07/12 08:34 AM Share Posted 26/07/12 08:34 AM I've lost the previous photo so here's anotherThis is the underside view. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 5d Gender: Male Location: Townsville Posted 26/07/12 10:20 AM Share Posted 26/07/12 10:20 AM The slots in the plastic on the wheel arch were used for a transmission cooler that was inside the guard (from memory anyway)The super trucks use bulk water spraying onto the rotors to keep them cool otherwise they'd last about a lap without it! Link to comment Share on other sites More sharing options...
knowhereman Donating Members 107 Member For: 13y 4m 13d Gender: Male Location: Torquay, Vic Posted 26/07/12 10:49 PM Share Posted 26/07/12 10:49 PM What Scatterbrain said, However!! Only cut slots on the flaps, dont remove the flaps completely. They introduce a high pressure area under the front bumper, that helps airflow into the the lower front grill. Also they will allow better airflow thru the slots you cut. Early BA's had the slots in the undertray for brake cooling, but were closed up early in the brake shudder saga. The theory was that dust and debrit were contaiminating the brakes causing shudder. That was the first reaction as the problem wasn't fully understood and it was a very cheap tooling mod with no piece price impact. Link to comment Share on other sites More sharing options...
