Boosting Issues, Any Ideas?
matt036
  • Moar Powar Babeh
  • Member For: 19y 5m 8d
Boost solenoid tables will be setup at a higher duty cycle to bypass more boost from the stock poundage actuator. This will cause an over boost if a higher rated actuator is fitted.
  • Member For: 14y 1m 14d
Here's another option.
Myself and a couple of friends went for is to fit an electronic boost controller and a 10PSI actuator for $17.50nz.
You have a greater range of boost pressures available and can control the characteristics of the boost relative to MAP, not an actuator cycle time percentage, which seems more logical. Also it doesn't need to be re-tuned to change the boost levels. This doesn't seem to throw out the AFR's.
I would be careful welding the actuator in-case the diaphragm or spring overheat.
  • Member For: 19y 4m
sex panda , theres a 11.8 actuator on the turbo your getting mate , as well as a ported housing , although a did notice a small crak starting around the port , but I doubt it would affect boost controlablily.
but im no sexpert
