ratter Member 6,793 Member For: 18y 7m 10d Gender: Male Location: @ my laptop Posted 01/08/14 06:03 AM Share Posted 01/08/14 06:03 AM M80 and M86 take different centres, the ute and sedan turbo take the same one Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 1m 17d Gender: Male Location: Brisbane Posted 01/08/14 06:47 AM Share Posted 01/08/14 06:47 AM Always wondered if ute and sedan had same centre.G6ET is m86, which would make it the only open centre m86 in the lineup I believe. Only N/A's have the m80 Link to comment Share on other sites More sharing options...
Slymeat Team Kickass Donating Members 1,926 Member For: 20y 11m 9d Gender: Male Location: Albion Park, NSW Posted 01/08/14 07:01 AM Share Posted 01/08/14 07:01 AM Is there anyway to check it by looking at the diff. Link to comment Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 1m 27d Gender: Male Location: Gold Coast Posted 04/08/14 11:53 AM Share Posted 04/08/14 11:53 AM Pretty sure if ya get your head under there on jacks or a hoist ya can see the bad cracks in the centre bush mate.. Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 8m 30d Gender: Male Location: A big bridge over a river in South Australia Posted 04/08/14 12:18 PM Share Posted 04/08/14 12:18 PM Give Harrop a ring.Vic.. 03 9474 0900They'll tell ya exactly what you need Link to comment Share on other sites More sharing options...
Slymeat Team Kickass Donating Members 1,926 Member For: 20y 11m 9d Gender: Male Location: Albion Park, NSW Posted 07/08/14 11:08 PM Share Posted 07/08/14 11:08 PM Got under the car to look at the diff apparently the M86 should have 8R 29C on the tag and the M80 should have 8R 29C imagine my surprise to find mine says 051016PA Ratio 2.73 S/N 001766, and nothing else rang Ford and they could not help, anyone understand this? Link to comment Share on other sites More sharing options...
Boosting_G6E Member 103 Member For: 8y 10m 17d Posted 20/06/24 09:29 AM Share Posted 20/06/24 09:29 AM On 17/04/2012 at 12:19 PM, Mr_4.0 said: I bought mY truetrac for 1200 bucks from memory and installed myself. Love it. How hard was it to fit? Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 268 Member For: 11y 6m 8d Gender: Male Posted 03/07/24 07:30 AM Share Posted 03/07/24 07:30 AM (edited) He has not been on here since 2018, so you might not be getting an answer from him. I am planning on fitting an LSD center to my G6ET. I have bought a cradle, to swap the torsen LSD centre into, but it is at a mates storage place. It also looks like I will be having a go a rebuilding a BA wagon diff first - so good practice before the G6ET gets done. I think that installing the LSD centre should be pretty straightforward. If the pinion bearings are being left alone, It looks like you just need to make sure that the side to side adjusters have the right preload on the crown wheel carrier bearings and the crown wheel is moved across to have the same clearance/play between the crown wheel and the pinion gear. There are a few videos on diff building showing measuring preload using a scale to see how much force is needed to get the diff to move. Try "Andy mechanic" on youtube, There is also a bloke in Tasmania who has done a good rebuild guide on the M86. If your diff is ok before you dismantle it, check how much force it takes to move using the scale before you dismantle, then make sure it is the same after rebuilding. Same goes for play between the pinion and crown wheel. Videos show using a stand and dial indicator to measure an actual amount of clearance, but if you are just wanting to make it the same as before, then a simple pointer and a marked starting and ending point for the movement of the pointer on a piece of cardboard should be enough - just make sure you have the same amount of movement of the pointer when you finish as you did before you started. I have not done a Ford diff, but many years ago, took a Torana banjo diff apart for the spider gears to be welded up, then reassembled it. That had similar side to side adjusters as the M86. I only did it all by feel - as in "clearance feels the same" and "preload/difficulty to turn feels the same" and it was perfect and ended up doing a lot of kilometers. Edited 03/07/24 07:34 AM by xr6tForMe Link to comment Share on other sites More sharing options...
DrG6E New Member 11 Member For: 6y 4m 28d Location: Adelaide Posted 08/07/24 12:20 AM Share Posted 08/07/24 12:20 AM I put the standard LSD (same as the XR6) in purely for grip, I was in a situation that I couldn't accelerate out of as the road was slightly wet and I was towing a 6x4 trailer, power to 1 wheel is useless with all that torque. Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 268 Member For: 11y 6m 8d Gender: Male Posted 09/07/24 07:13 AM Share Posted 09/07/24 07:13 AM How did you find the upgrade to the LSD over the standard G6E diff? I have been pretty impressed with the grip of my G6E turbo given that they do not have an LSD, but I am installing one as I expect it to be better again. Link to comment Share on other sites More sharing options...
