450Kw Asking Too Much On Standard Internals
P_BA_XR6
  • Member For: 13y 2m 9d
Its not Just built bottom end then there is rods oil pump pistons etc
You are paying for the labour to take the engine out so add a few things to make it stronger.
Also by doing this you aren't going to get more power just making the engine stronger.
yep. I agree
Guest XR09
  • Guests
Fg XRT and F6 motors are almost identical.
FG F6 uses Mahl pistons and that's it.
Top ends are identical from the XT to the F6.
The XrT uses a different gasket to alter comp.
The F6 uses a different gasket and bigger Turbo. (Or the same size as the XRT BF)
Definately fit a new Oil pump. And feed to the journals if you can.
  • Member For: 16y 26d
Exhaust valves are definitely different on the turbo engines as are valve springs...
But thought comp is altered by the concave depth in the piston.
Edited by Paulie2256
  • Member For: 16y 11m
isnt that what a bottom end is ?
