  • I Lead Not Follow...
  • Member For: 13y 15d
Evildaifu,thanks very much buds this is a helpful vid..been meaning to do the misses ba window for some time now,its driving me insane.I used the powder stuff,but this seems easier and cleaner I think..
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 9m
Ya know what they say "Happy Woman - Happy Home" :roflmbo:
Have to repeat roughly every 3 months but is a cheap as chips workaround. Use the pure silicon spray though - WD-40 spray stinks and if you use that you'll need to drive around with window down for a couple of weeks :nono:
Yeah I tried graphite as well but it's a bugger to get in and for me wasn't as effective as silicon spray.
Hope it helps :beerchug:
  • Member For: 16y 6m 21d
Found my own answer in the Workshop Manual:
Power window operates sluggishly
9. Check the regulator and window runs for binding.
Adjust the runs, repair and lubricate the regulator.
Lubricate the runs with silicone lubricant.
10. Check for frayed insulation where the window
wires may partially ground. Check for loose
connections which will cause high resistance.
11. Check motor current draw during operation (place
an ammeter in series with the ground lead of the
battery). Motor current draw should not exceed 12
amps during normal operation and should exceed
20 amps at stall. If the current is above 12 amps
during operations of the window, readjust the
glass mechanism. If the stall current is below 20
amperes at stall, look for poor electrical
connections.
12. Motor current draw when disconnected from the
regulator plate should not exceed 5 amps.
  • Cruise Whore
  • Moderating Team
Hi Mate, no residue on the glass that I can see.
I've got a tint but my tint was peeling before I tried this workaround. My tints been peeling on all 5 windows because the previous owner had a crap tint job done - so can't comment authoratively. But as you can see in the vid on the front edge of my drivers side window - the tint is fine. I've done this workaround 3 times now and it does not have affected the tint.
