TXR05 Member 181 Member For: 13y 8m Gender: Male Location: Brisbane QLD Posted 16/04/12 11:08 AM Author Share Posted 16/04/12 11:08 AM there is a diagnostic dyno near my place. Costs about $400, but they test compression and a whole heap of other sh*t.Might check them out. Link to comment Share on other sites More sharing options...
TXR05 Member 181 Member For: 13y 8m Gender: Male Location: Brisbane QLD Posted 27/06/12 04:25 AM Author Share Posted 27/06/12 04:25 AM So I still haven't figured out what the go is! anyone else got anymore ideas ?It feels as if the cams are not kicking in like they should be! drives fine up untill 3500RPM where the power difference doesnt seem to change much from 3/4 throttle to full throttle.makes all the noise like it wants to go, but just goes no where. Not logging any error codes, making 13.5 PSI instead of 12 PSI. Took it to the dyno who told me its because the engine is old ( 90,000KM )Could a fault O2 sensor cause this ? TPS ? Or could this be because of my non genuine coils ( doesn't misfire at any RPM or boost ).Just lacking the suddon oomph of boost at 3500 ( but still hits it fine ) Link to comment Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 13y 10m 7d Gender: Male Location: Gold Coast Posted 30/06/12 05:07 AM Share Posted 30/06/12 05:07 AM Probably wrong maybe check the vct plugs under the coil cover for looseness Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 14y 4m 3d Gender: Male Location: sydney Posted 30/06/12 02:42 PM Share Posted 30/06/12 02:42 PM Probably wrong maybe check the vct plugs under the coil cover for loosenessI had a similar problem lot of boost an no power, pain in the arse to find the problem, but I found it an it was my turbo, it was rooted, my rear turbine wheel was damaged an that's what caused my loss of power. What I sugest you to do is put it on the dyno an see what power you get check the tune while your at it. I relise you have a manual mabey your clutch is slipping a bit. Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 3m 10d Gender: Male Location: Muswellbrook,NSW Posted 02/07/12 07:37 AM Share Posted 02/07/12 07:37 AM (edited) ^^^ 2nd this , couldnt find to reason to be down over 50Kw , on the way home after the dyno check turbo died , new turbo , and wheelspin city ! Edited 02/07/12 07:37 AM by quadie Link to comment Share on other sites More sharing options...
TXR05 Member 181 Member For: 13y 8m Gender: Male Location: Brisbane QLD Posted 04/07/12 01:05 AM Author Share Posted 04/07/12 01:05 AM (edited) turbo sounds fine though. Not clutch slip as it holds in 6th under load and spins the wheels easy enough.What would be the best way to see if the turbo is buggered ?It still holds boost and makes it just fine. On the shut down it all sounds normal. Edited 04/07/12 01:07 AM by TXR05 Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 1m 22d Gender: Male Location: Perth, WA Posted 04/07/12 07:42 AM Share Posted 04/07/12 07:42 AM CAT possibly damaged? Would limit flow above certain rpm. Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 7m 20d Gender: Male Location: south east suburbs Posted 04/07/12 10:01 AM Share Posted 04/07/12 10:01 AM His checked that , possible muffler blocked? Theres quite a few reasons to sort through. Link to comment Share on other sites More sharing options...
TXR05 Member 181 Member For: 13y 8m Gender: Male Location: Brisbane QLD Posted 04/07/12 10:54 PM Author Share Posted 04/07/12 10:54 PM I don't know if it would be the muffler, would that make the car sound different? The odd thing is the car seems to have more power in the morning. Right after the car warms up it's got a fair amount more power than what it does if it's been running for a couple of hours. Yet the intake temps remain the same. Well maybe 5 degrees different. I'm going to take it back to the dyno when my tax comes through. Hopfully it's something stupid. I was watching a vid when I first got the car, and it deffiently went alot harder than what it does now. Link to comment Share on other sites More sharing options...
