JVK Silver Donating Members 751 Member For: 19y 2m Gender: Male Location: North West Hot Hell,VIC Posted 14/04/12 10:52 PM Share Posted 14/04/12 10:52 PM I think you will find that you need a bit more boost to run the numbers your after. You shouldnt need an actuator at that power range on a FG neither. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 2m 1d Gender: Male Posted 15/04/12 02:59 AM Share Posted 15/04/12 02:59 AM http://www.fordforums.com.au/showthread.php?t=11313324&highlight=dump+pipe+restrictor Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 6d Gender: Male Location: Gold Coast Posted 15/04/12 04:46 AM Share Posted 15/04/12 04:46 AM I think you will find that you need a bit more boost to run the numbers your after. You shouldnt need an actuator at that power range on a FG neither.Mine runs 13psi and currently makes 310rwkw, by the same tuner. It's best run was 315rwkw. I use the standard actuator.I run the Venom bolt up cat, factory F6 injectors, PWR stepped cooler, coolerworx pipe kit & SS Growler. This combo has been proven to deliver 300rwkw time after time on FG.If unhappy mate, go back. You would not meet easier guys to deal with and I'm sure they will work through it with you. 3 Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 6m 28d Gender: Not Telling Posted 15/04/12 05:04 AM Share Posted 15/04/12 05:04 AM Hey mate here is my 09 FG on the dynoThe green shows stockthe pink is cooler and injectors onlythe black is cooler,injectors and exhaustThe smaller turbo does run out in the top end and not having the turbo mods wont help this and boost does fade.I dont know about "making it with ease" as with whats been said before, all dynos are differentwhat did your tuner say?When you say stock, was that stock with or without a tune? Cheers Link to comment Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 14y 7m 27d Gender: Male Location: Perth,WA Posted 15/04/12 05:30 AM Share Posted 15/04/12 05:30 AM (edited) yeah mate green shows from factory with a K&N (246rwkw) Edited 15/04/12 05:30 AM by MurdoK 1 Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m Gender: Male Location: North West Hot Hell,VIC Posted 15/04/12 06:08 AM Share Posted 15/04/12 06:08 AM Mine runs 13psi and currently makes 310rwkw, by the same tuner. It's best run was 315rwkw. I use the standard actuator.I run the Venom bolt up cat, factory F6 injectors, PWR stepped cooler, coolerworx pipe kit & SS Growler. This combo has been proven to deliver 300rwkw time after time on FG.If unhappy mate, go back. You would not meet easier guys to deal with and I'm sure they will work through it with you.But yours spikes closer to 14 initially then tapers to about 12.3 at peak power. 1 to 1.3 extra lb of boost can make a difference and so can the restictor ring if they left it in after fitting the hi flow cat.But as they say ,all cars are different. Link to comment Share on other sites More sharing options...
James xr6fgturboute Member 35 Member For: 13y 1m 3d Gender: Male Posted 15/04/12 07:07 AM Author Share Posted 15/04/12 07:07 AM Mine runs 13psi and currently makes 310rwkw, by the same tuner. It's best run was 315rwkw. I use the standard actuator.I run the Venom bolt up cat, factory F6 injectors, PWR stepped cooler, coolerworx pipe kit & SS Growler. This combo has been proven to deliver 300rwkw time after time on FG.If unhappy mate, go back. You would not meet easier guys to deal with and I'm sure they will work through it with you. yeah I'm going back this week To get a 4inch dump an cat hopefully it will sort everything out 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 6d Gender: Male Location: Gold Coast Posted 15/04/12 07:09 AM Share Posted 15/04/12 07:09 AM (edited) ^^^ nice. Edited 15/04/12 07:09 AM by Bomber Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 8m 25d Gender: Male Posted 15/04/12 10:13 PM Share Posted 15/04/12 10:13 PM LOL, he only made 280rwkw's, not having a laugh at you James, just the other two that didn't read the topic right....A lot of tunes including mine, peak at a certain psi, then tapper off to lower boost, its mainly due to stock actuators or they way the tuner has tuned it, to give a bit off a rush at the start...Not too sure whats holding it back, it should be making a bit more, have a look in the 300rwkw section and see what other FG's have done, I haven't heard of the dump thing though...I was just having a laugh at Mark.On a serious note I'd be checking to see if that restrictor ring is still in there. 1 Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m Gender: Male Location: North West Hot Hell,VIC Posted 16/04/12 09:20 AM Share Posted 16/04/12 09:20 AM Honestly a 4" dump is overkill with the little turbo if that's what your staying with.Better would be one of Venoms dump & cat assy or maybe a 3.5 " dump and cat. 1 Link to comment Share on other sites More sharing options...
