LukeF6E Member 2 Member For: 13y 8d Gender: Male Location: Just north of Brisbane Posted 13/04/12 09:23 AM Share Posted 13/04/12 09:23 AM Hi. This is my first post on this site so go easy on me.I bought a second-hand F6E in January with only 15000km on the dial and I love it. Except for the suspension. I have read fairly exhaustively on this forum and can't seem to find an answer to my query. I want to put some suspension in that handles better than the stock gear but don't want to lower the ride height at all. My local spares guy contacted King Springs HQ who said that they don't make any for the FPV yet!!! I would really like to hear from someone with some real life experience with this fix and would appreciate your comments.I have plans to do some upgrades a little bit down the track but thought it best to wear a bit of the warranty out first.Thanks for your help. This is the only photo I have so far... Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/ Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 7m 12d Gender: Male Location: Southern Highlands NSW Posted 13/04/12 09:33 AM Share Posted 13/04/12 09:33 AM Wholesale suspension. They are a site sponsor, well at least untill the end of the month. Pat will be more that happy to point you in the right direction Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1222153 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 11m 6d Gender: Male Location: Gold Coast Posted 13/04/12 09:48 AM Share Posted 13/04/12 09:48 AM (edited) ^^^^ that or given your location, I would contact Kings direct mate - ask for Steve D. They also have a fitting service at the factory on the goldie. You would just need to take it elsewhere for an alignment.Your car would most likely be slightly lower than XR standard height which is 365mm centre of hub to guard. Measure what it is currently and they should be able to match up some springs within maybe 10mm which is bugger all really. I'd be thinking SSL's allround will get you close to what you're after and as you've got 19's, ground clearance won't be an issue. The shocks would also be ok with them unless you want to upgrade at the same time. Edited 13/04/12 09:55 AM by Bomber Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1222159 Share on other sites More sharing options...
Guest XR09 Guests Posted 13/04/12 11:43 AM Share Posted 13/04/12 11:43 AM I wouldwalk from that man who told you that.Strait after I biatch slapped the mother.Mate the only diff on XR to xt to FPV is sping and damper rate. And I think 20mm ride height across the range.Seriousley a dickhead.If ya want the same height as FPV go ssl kings and Koni reds. It will transform your car by miles. Truly will give it a Euro ride. You wont need to change bushes with this set up. but a decent suspension guy will check them out well before he bolts your new shoite in anyway. Don't be suprised if your OEM's are shagged with only a few K's on them. Their squishy little useless suckers std anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1222211 Share on other sites More sharing options...
Rubberman Member 37 Member For: 14y 5m 7d Gender: Male Posted 13/04/12 11:34 PM Share Posted 13/04/12 11:34 PM nice looking vehicleThe F6E that has Brembo's all round and doesnt it have the 6 piston callipers up front ?white is the best colour ! Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1222320 Share on other sites More sharing options...
LukeF6E Member 2 Member For: 13y 8d Gender: Male Location: Just north of Brisbane Posted 14/04/12 08:30 AM Author Share Posted 14/04/12 08:30 AM Thanks - I love it (I might have already said that). I had only had it 2 weeks and some low-life keyed one of the doors in the carpark at work. To say I was homicidal would be an understatement....It does have the Brembos all round - 6 piston up front and 4 in the rear so it stops in a hurry. I nearly hurt myself a couple of times when I first drove it.Thanks for your replies regarding my suspension query too. I will give Pat a call next week and get some more info. From what I can gather, based on my car being the same ride height as the XR6, I would need KFFL40 in the front and KFRL68 in the rear to keep it standard and SSL front and SL rear to drop it around 30mm (and retain the factory forward raked sill height). Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1222519 Share on other sites More sharing options...
andrich Member 94 Member For: 16y 1m 16d Posted 29/04/12 01:02 PM Share Posted 29/04/12 01:02 PM how good does white look!! love it mate.I recently put bilsteins in my T and they are awesome. I would definitely recommend them; they ride and handle very well. Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1229199 Share on other sites More sharing options...
Guest XR09 Guests Posted 30/04/12 04:45 AM Share Posted 30/04/12 04:45 AM Not sure about what the std ride height is..My suspension is hight adjustable. And have found that the car performs best between a 340mm and 350mm ride height.340mm being for stability and 350mm more for turn in and change of direction.They scrape on just about everything running the std height anyway, which would have to be about 355 to 360 I think.ps I love your car Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1229481 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 10d Gender: Male Location: SW Sydney Posted 30/04/12 05:25 AM Share Posted 30/04/12 05:25 AM You only need to change your shocks for what you need mate Throwing a set of Koni's or Bilsteins in the car will make it handle and ride better with out any ride height change. As mentioned the standard bushes in these cars are very soft. Your car will destroy the front upper control arm bushes and the front lower caster bush. Changing these will result in a more direct feel and you will get better tyre life too. Also keep in mind the rear end - the diff bushes will flog out, so look at changing these with super pro products too. Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1229503 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 10d Gender: Male Location: SW Sydney Posted 30/04/12 05:26 AM Share Posted 30/04/12 05:26 AM On 13/04/2012 at 9:33 AM, RHR said: Wholesale suspension. They are a site sponsor, well at least untill the end of the month. Pat will be more that happy to point you in the right directionI'll be here til the end of May thankyou! Link to comment https://www.fordxr6turbo.com/forum/topic/79706-fg-f6e-suspension/#findComment-1229504 Share on other sites More sharing options...
