orangeute338 Suspended 260 Member For: 16y 6m 8d Gender: Male Posted 09/04/12 11:53 AM Share Posted 09/04/12 11:53 AM has anyone had any luck with wrapping it? Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 7m 13d Gender: Male Location: Sydney Posted 13/04/12 05:04 AM Author Share Posted 13/04/12 05:04 AM Found a combination of these materials to use on the inside of the airbox panels.http://www.jaycar.com.au/productResults.asp?keywords=insulation+sound&keyform=KEYWORD&SUBMIT.x=0&SUBMIT.y=0http://www.jaycar.com.au/productView.asp?ID=AX3687Will be trying out over the next few weeks when I get around to it.If it doesn't work, I am trying to find a shop that sells 4" Black Silicone piping in graual 90deg bends. Was thinking of wrapping the stainless steel intake pipe in this too. Cut and clamp if I can't fit in on. Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 28d Posted 13/04/12 08:01 AM Share Posted 13/04/12 08:01 AM maybe try wrapping the intake pipe in roof flashing tape too, its cheap enough so no real loss if it doesn't work.Bunnings sell it. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 7m 13d Gender: Male Location: Sydney Posted 20/04/12 11:33 PM Author Share Posted 20/04/12 11:33 PM I had a bit of experimentation this week.I fitted insulation tape and foam (dynomat) to the inner side of the airbox lid. Not much change.Also special foam from Jaycar with Valleys/peaks to the bottom of the airbox/battery tray. Some sound reduction but not enough.Finally removed both airbox panels entirely which just had the stainless pipe connecting the pod filter to turbo open in engine bay.Sound reduced!Had a talk to a few people (V-Sports were right on the money) and thought it was the metal pipe clamp (holding 4" Stainless intake to pod filter) rubbing/vibrating on the metal panel of the airbox as the engine moved if that makes sense.I.e. see the Plazmaman kit below.See how the hole above for the intake pipe has a rubber protector. Mine does not.Problem may be solved!Just need to fit some rubber, then flexible pastic piping around the inside of the hole and also dymat this panel too.Will be wrapping the stainless intake pipe in roof flashing tape and fibreglass heat insulation tape too just to be sure sure later. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 20d Gender: Male Location: Auckland, New Zealand Posted 21/04/12 12:39 AM Share Posted 21/04/12 12:39 AM I have a rubber insulator there but still get unwanted sucking noise. I might end up going back to the original air box on the passenger side. Will make changing the filter a lot easier. I was going to put the air box on the drivers side but not enough room :( Link to comment Share on other sites More sharing options...
orangeute338 Suspended 260 Member For: 16y 6m 8d Gender: Male Posted 21/04/12 01:22 AM Share Posted 21/04/12 01:22 AM ISee how the hole above for the intake pipe has a rubber protector. Mine does not.Problem may be solved!that tiny bit around the pipe wont make much difference, the noise is still coming out from everywhere where its not sealed. that's why factory air boxes are a sealed box with one intake not like the after market ones that are just a 3 sided box...but saying that the nizpro one is the same box but the thick cast intake piping doesnt make the sound so it doesnt matter what the box is like. also the rest of the piping makes a difference, alloy piping will be louder then rubber etc...at the start I made throttle body relocation and used thin wall bend off the plenum and it made more suction noise, changed to thick wall cast bend and went away...its all in the piping. make a intake out of thick plastic and it will be quiet, get some 3inch pvc bends from bunnings and try it out Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 7m 13d Gender: Male Location: Sydney Posted 21/04/12 02:21 AM Author Share Posted 21/04/12 02:21 AM that tiny bit around the pipe wont make much difference...........You have misread what I meant. The (unique to my car) scraping intake noise (far louder than the induction noise) appears to have been coming from direct metal to metal contact between the 4" clamp holding the filter onto the intake pipe, and the airbox side plate itself, with the hole. As the engine vibrates/moves, the clamp was rubbing on the side of the thin metal plated airbox. It is a unique problem to this particular airbox which does not have that rubber ring.I will be also be dynomatting this inner side airbox panel as well as wrapping the intake pipe in a few layers of Aluminium/foam insulation tape as well as fibreglass tape. Also have some high temp rubber hose which I am considering wrapping between layers of the intake pipe too.Left over dynomat may even go on the underside of my bonnet or that matt under the bonnet. Link to comment Share on other sites More sharing options...
orangeute338 Suspended 260 Member For: 16y 6m 8d Gender: Male Posted 21/04/12 05:33 AM Share Posted 21/04/12 05:33 AM well the first post you were talking about a loud sucking noise, hose clamp rubbing isnt induction noise Link to comment Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 3m 9d Gender: Male Location: Melbourne Posted 21/04/12 06:05 AM Share Posted 21/04/12 06:05 AM I have a 4" pod hooked to the turbo in an aluminium airbox with Dynamat of all sides and the bonnett dynamatted, it makes no difference to the hissing sound, rushing air noise is very hard to shut up. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 7m 13d Gender: Male Location: Sydney Posted 21/04/12 07:11 AM Author Share Posted 21/04/12 07:11 AM Damn! I think you guys are right.I just finished dynomatting the entire airbox and fitted a rubber ring in the side airbox hole.Very optimistic on the test drive.........................but noise still there.Next step is wrapping the intake pipe in several layers of different materials.Maybe next weekend. :( Link to comment Share on other sites More sharing options...
