turbowelshy89 Member 147 Member For: 14y 6m 28d Posted 05/04/12 09:22 PM Share Posted 05/04/12 09:22 PM I'm looking at getting a set of cams due to the mob who where refreshing my head snapped one of the cam sensor lobes of the exhaust cam. I'm looking at a stage 2 set from Jim Mock Motorsports but am just wondering is.modding the cams worth while or should I just replace it with a standard one. I'm looking at about 400rwkw when the Ute is put back together and tuned... Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 11m 26d Gender: Male Location: Geelong, Victoria Posted 05/04/12 09:38 PM Share Posted 05/04/12 09:38 PM Read it a lot on here that cam upgrades aren't necessary. 400kw is easy on stock cams. Come to think of it I can't remember the last build I read that they changed cams. Just get standard and save the money for the 400kw mods Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 1d Gender: Male Location: SE Melbourne Posted 06/04/12 12:52 AM Share Posted 06/04/12 12:52 AM Any cam change you do would only be to change the way the power is delivered. I also know people change cams when the stock computer can no longer keep up with the VCT changes required. Cams at 400 will just use more fuel IMO. Link to comment Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 6m 28d Posted 06/04/12 12:03 PM Author Share Posted 06/04/12 12:03 PM All the parts are there too make around the 400 mark are ready to go just got to sort out the drama with his exhaust cam... Yea I thought the stock ones were good for over what I'm chasing just thought I'd ask cheers... 1 Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 7m 28d Gender: Male Location: south east suburbs Posted 06/04/12 12:43 PM Share Posted 06/04/12 12:43 PM Cams make more of a difference on a big turbo setup. 1 Link to comment Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 6m 28d Posted 06/04/12 11:09 PM Author Share Posted 06/04/12 11:09 PM Ok cool I'm goin a 35/40 with a billet wheel an .7 front cover... Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 7m 28d Gender: Male Location: south east suburbs Posted 06/04/12 11:39 PM Share Posted 06/04/12 11:39 PM std cams is sufficient enough for 400rwkw + with that turbo. Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 5d Gender: Male Posted 07/04/12 12:02 AM Share Posted 07/04/12 12:02 AM standard cams are good for 1000hp, 11mm lift is insane for a std camshaft. check out the xft f6 Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 8m 3d Gender: Male Location: E. Maitland Posted 07/04/12 11:05 PM Share Posted 07/04/12 11:05 PM According to atomic they will deliver more power on less boost and spool quicker Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 5m 5d Posted 08/04/12 03:30 AM Share Posted 08/04/12 03:30 AM According to atomic they will deliver more power on less boost and spool quickerNot quite, you will need to have your head ported and flowed as well to gain those sort of results. Cams are mainly for top end power increases and you will loose low down response if just just changing cams without head work as well. Link to comment Share on other sites More sharing options...
