Goliath Member 383 Member For: 14y 9m 16d Gender: Male Location: Sydney Posted 04/04/12 11:03 PM Author Share Posted 04/04/12 11:03 PM hmm might give it a go seeming its fairly harmless on the wallet. Doubt I would feel any difference running stock tune, but I'd know it was there haha.Thanks for the responses guys. Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1218534 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 27d Gender: Male Location: Townsville Posted 05/04/12 12:46 AM Share Posted 05/04/12 12:46 AM On 04/04/2012 at 9:01 AM, Benny said: My old XR was comfortably marking 340rwkw with the factory filter and airbox. With the airbox lid lifted for a run (no filter) it made no improvement. But in saying this I have heard people experience gains running a factory tune and airbox with K&N.Benny.that's funny as I have seen on multiple cars the reasonable gain in both low end torque and hp due to less restriction of the stock air filter and box. The turbo spools quicker making more boost down low and although its not a massive gain it is free! This was also noticable with my rapids big intake system, removing the cone style K&N filter the car came on boost about 300rpm earlier giving an increase in torque.Free hp is good hp. Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1218563 Share on other sites More sharing options...
Black_S15 Member 90 Member For: 15y 2m 20d Gender: Male Location: sydney Posted 21/05/12 02:15 PM Share Posted 21/05/12 02:15 PM bit of a thread hi jackbut from what ive gathered, the K&N filters are alot less restrictive then the factory thick ford filters, this will mean more air entering the turbo, but the stock tune will still be using the same amount of fuel... does this mean a less restictive filter will make the car run lean? is a retune required when changing to a less restrictive filter or a POD? Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1240991 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 11d Gender: Not Telling Posted 21/05/12 09:25 PM Share Posted 21/05/12 09:25 PM (edited) On 21/05/2012 at 2:15 PM, Black_S15 said: bit of a thread hi jackbut from what ive gathered, the K&N filters are alot less restrictive then the factory thick ford filters, this will mean more air entering the turbo, but the stock tune will still be using the same amount of fuel... does this mean a less restictive filter will make the car run lean? is a retune required when changing to a less restrictive filter or a POD?No retune required. The factory ECU has this all under control. However, to gain the best outcome with a K&N filter, improving cold air intake into the factory box will improve throttle response. I personally have 150mm alloy ducting ( pop riveted in lower section of air box) running to the headlight, and definned both upper and lower air box sections (internal fins designed to create turbulence, therefore to reduce induction noise). Car spools nice from around 1800rpm, were as before it was around 2300rpm. I should also add that this was done in conjuction with port and polishing crossover, and wrapping intake piping with aluminium tape. Cheers Edited 21/05/12 09:28 PM by Impellor Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1241023 Share on other sites More sharing options...
broke Donating Members 229 Member For: 13y 6m 17d Gender: Male Posted 22/05/12 03:24 AM Share Posted 22/05/12 03:24 AM On 21/05/2012 at 9:25 PM, Impellor said: No retune required. The factory ECU has this all under control. However, to gain the best outcome with a K&N filter, improving cold air intake into the factory box will improve throttle response. I personally have 150mm alloy ducting ( pop riveted in lower section of air box) running to the headlight, and definned both upper and lower air box sections (internal fins designed to create turbulence, therefore to reduce induction noise). Car spools nice from around 1800rpm, were as before it was around 2300rpm. I should also add that this was done in conjuction with port and polishing crossover, and wrapping intake piping with aluminium tape. Cheersbeen thinking of modding the stock box recently when I throw a K&N in there. thinking a largish hole in the bottom or the side right hand side (that sits next to the front quarter panel.) would like some more noise. will probably screw some kind of mesh over the hole just to stop any debris from somehow making it's way in the box. good to know that it's worth while. Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1241171 Share on other sites More sharing options...
stroller SHLAMBD. Member 259 Member For: 12y 11m 25d Gender: Male Location: Perth NOR Posted 22/05/12 06:17 AM Share Posted 22/05/12 06:17 AM Yeah I've got a k&n panel filter in stock box with a few 100mm holes drilled underneath and infront 1 Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1241218 Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 18y 3d Gender: Not Telling Location: banned Posted 22/05/12 06:25 AM Share Posted 22/05/12 06:25 AM (edited) Congrats mate... Edited 22/05/12 06:28 AM by dazzler Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1241220 Share on other sites More sharing options...
stroller SHLAMBD. Member 259 Member For: 12y 11m 25d Gender: Male Location: Perth NOR Posted 22/05/12 10:36 AM Share Posted 22/05/12 10:36 AM lol at pointless comment^ Link to comment https://www.fordxr6turbo.com/forum/topic/79569-kn-filter-replacement/page/2/#findComment-1241420 Share on other sites More sharing options...
