possum Donating Members 553 Member For: 15y 11m 18d Gender: Male Posted 29/03/12 08:16 AM Share Posted 29/03/12 08:16 AM Have just fitted a gtx3582r onto an fg xr6 turbo and I'm very interested to see how it performs in comparison to a standard turbo with .7 front cover Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216254 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 2m 5d Gender: Male Location: Gladstone, Queensland Posted 29/03/12 09:41 AM Share Posted 29/03/12 09:41 AM On 28/03/2012 at 8:56 PM, Bonjaz said: Have a chat to dave about it, he was the one that turned me off the gtx, he has a gt3540 with a to4 front wheel waiting to go on his f6 im pretty sureYeah its still hasnt been fitted, Im still debating what way to go Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216276 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 5m 3d Gender: Male Location: CQ Posted 29/03/12 10:27 AM Share Posted 29/03/12 10:27 AM I went with a 35/40 with a .7 front so far so good have a mild tune in it atm, heading back to mackay on the 12th to try crack the 400kw Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216294 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 3d Gender: Male Location: OZ Posted 29/03/12 11:12 AM Share Posted 29/03/12 11:12 AM On 28/03/2012 at 9:17 AM, 45T-XR said: Actually, Id be interested to see how a gt35/40 stock turbo with billet stock 62ish mm wheel with a .7 housing would go?Well that's exactly what a GTX 35 is :-) Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216311 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 3d Gender: Male Location: OZ Posted 29/03/12 11:24 AM Share Posted 29/03/12 11:24 AM On 29/03/2012 at 3:19 AM, RAP1D said: This is what Veva has, the compressor wheel is basically the same diameter but a direrent fin design which cuts in close the the centre shaft, allowing more airflow. This is pretty much the same deal as the GTX compressor billet wheels.When you change to a larger / heavier compressor wheel, lag will increase slightly as it will when you increase the compressor housing AR, as in going from a standard housing of .5, to a larger .7 AR housing.A good tuner will be able to alter to the tune to make up for this loss... Vevas FG is definatley no lag monsta.I posted a datalog graph of 0.5 to 0.7 cover spool difference using street data and the lag difference was buggerall. An AR change on the turbine housing makes a significantly greater difference than the compressor AR going by my data with a 66mm TO4Z garbage wheel. In terms of spool loss my dyno data shows 700 odd rpm loss and bulk kw at 3000rpm, in reality though my data shows less loss on the street. There is absolutely no way in the world any tuner can recover that loss via a calibration change. Totally unrealistic expectation unless your tune was total garbage to start with.No one has mentioned the HTA version of the GT35 which has a slightly smaller compressor turbine in comparison to the GTX35. Same size 0.7 cover.I have never experienced one but I regret not going the Mr Turbo 61mm billet wheel in the 0.5 cover. Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216319 Share on other sites More sharing options...
tekaani Donating Members 163 Member For: 15y 10m 22d Posted 30/03/12 04:29 AM Share Posted 30/03/12 04:29 AM 450rwkw on 18 psi, your talking e85 right veva? Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216575 Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 10m 21d Gender: Male Location: E. Maitland Posted 30/03/12 04:50 AM Share Posted 30/03/12 04:50 AM (edited) On 26/03/2012 at 10:21 AM, Vevapower said: I'm leaving my missus for that ^^^ Edited 30/03/12 04:51 AM by Rhino1980 Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216586 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 3m Gender: Male Location: Sydney Posted 30/03/12 06:37 AM Share Posted 30/03/12 06:37 AM On 30/03/2012 at 4:29 AM, tekaani said: 450rwkw on 18 psi, your talking e85 right veva?Yes mate E85. 425 on 98 Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216634 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 21d Gender: Male Location: Sydney NSW Posted 30/03/12 07:51 AM Share Posted 30/03/12 07:51 AM Toads, your saying you logged hardly any difference in lag between the .5 to the .7 compressor housing, which is basically what I stated, the small amount of lag CAN be removed through tuning , such as inlet cam timing , and as a lot of tuners don't touch cam timing in an initial tune, a tweak later can yield good improents in spool up, maybe not a huge change, but enough to improve on the .7 housings minor lossGreater loss when increasing the A/R on the turbine (exhaust) housing is right, but what housing did you change to? A back to back test you did must have been two housings both externally gated... Or is there a bigger A/R internal gate housing that will bolt to the ford 35/40 t3 frame that you used for the test?The topic isn't really concerned with changing the turbine housing, non of the turbos mentioned have.Not having a go mate, your post just reads odd when you mentioned turbine housing. Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216654 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 3d Gender: Male Location: OZ Posted 30/03/12 08:11 AM Share Posted 30/03/12 08:11 AM I am odd lol. I just tell it as I see it which is based on what the data says.Nah wiggums 0.7 cover actually spooled better than my 0.5 cover with the 66mm wheel. The shape of the curves were identical.We both have modified cam tables, and both of us have played with cam timing a fair bit and shared info. Playing with the tune will never recover the lost spool on my car. If I went out and got a twin scroll / twin gate manifold then it would e a different story! XYZ's (think it was him) car is a good example, his big GT42 on a good manifold out spooled his GT3566r on the stock manifold....going by his dyno sheets.I have an external gate and wiggum has an internal..both same turbine AR. He still out spools me.He uses HP though which is missing a cam max retard limit table which is TP based. Link to comment https://www.fordxr6turbo.com/forum/topic/79461-gt3566r-gt35-with-t04z-front-end/page/4/#findComment-1216668 Share on other sites More sharing options...
