Lightweight Ute Tray
allmtr
  • Member For: 16y 4d
Finally filed enough off the calipers to get the prostars on
Really needs the rear prostars and 275 MT's now....
and started on the Jaz fitment
Edited by allmtr
  • Like 2
Yeah not much more I'm going to do weightwise. May take a crossmember to my chassis guy and see if doing it in moly will save much. When I change to the plazmaman cooler and FG manifold it'll save a bit more but, generally, I'm done with weight reduction
It's as per my sig at the moment. I have a FG intake and exhaust manifold for it and a 1000hp Plazmaman cooler in the shed to go on it. Next pay I'll be getting a plazmaman fuel rail and the pay after that some id2000's. I'm running an A1000 pump and when I change over the manifold I have a 1200hp turbosmart reg to fit up. I'm only on a standard (early) motor so low 300's will pull it up until I redo the motor. I have some BF II rods in the shed but I might just buy an FG bottom end
  • Member For: 17y 8m 14d
If your using the BA bottom end, id be more inclined to go with E85 fuel if you want to push it hard. The most I made on the Ba standard engine was 330rwkw on 100oct with the std crossover and plenum.
That netted me a 11.2, so you should run a 10 no problem with that power, as you have reduced the weight substantially.
So you could look at that option for now, until your ready to drop a stronger motor in.
