  • Member For: 13y 1m 11d
Hello everyone. (first post)
Recently I have just purchased a 2004 BA XR6t, Happy with the car runs well, drives smooth.
After purchasing the car, I wanted to be satisfied with it all, I did a service myself.
After reading all the talk about caring for your turbo I decided to check the oil feed lines, The stock hard pipe line to the trubo was blocked. So I contacted my mate at ford. He got me a new hard line and an FG filter. so I was happy about that.
Now since joining the forums, I have read that everyone gets rid of the Hard lines, after further reading everyone is different about which kit to get.
(Earls, EMT, Superflow.)
All I want to know is which kit is best to get (I dont want to start a roit between members).
side note - I read on the item descriptions for the new kits that they remove the stock filter. that being said what happens to the Oil pressure sensor that is on the filter in the block?
https://www.fordxr6turbo.com/forum/topic/79373-recently-bought-a-xr6t/
  • Member For: 15y 3m 12d
Not everyone uses those kits. I have the filter removed with the factory line. The sensor will always be back in the same spot as it is need for the car to run.
I have just remember that the filter is kept in by a circlip, so u can remove it from the fitting, so I answered my own question about the oil pressure sensor.
So you havent had any problems with the hard lines?
  • Thooperrrrrrr
  • Member For: 13y 9m 28d
There's a member on here running massive power who uses the stock hard lines with an earls filter, has no dramas.
Can't recall who but I'm sure they'll post in here or someone else will with the name.
Well that's my next step, Beefing it up a bit. I got it listed down what ill need from the forums.
When I get back from karratha, might head into Xrtreme Ford Tunning, see what they recommend.
Edited by BloodOrangexr6t
  • Member For: 15y 6m 5d
XFT will help you out with this one, they have a great rep on here
