mic Donating Members 1,725 Member For: 17y 2m 23d Gender: Male Posted 26/04/12 04:28 AM Share Posted 26/04/12 04:28 AM so what are the specs mate ?? Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 17d Gender: Male Posted 26/04/12 04:36 AM Author Share Posted 26/04/12 04:36 AM What specs are you after?RB26 with 40thou over forged pistons, H beam rods, ACL bearings. All balanced. Probably going to put a sump baffle in it.550cc Sard injectors and walbro in tank.R34 N1 turbo's, HKS dumps, unknown front pipe, 3" 100cpi Ballistic cat, 3"catback.Made 255rwkw on 16psi last time and Racepace said something in the exhaust was holding it back. Not sure what though. Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 2m 23d Gender: Male Posted 26/04/12 06:05 AM Share Posted 26/04/12 06:05 AM yeah just the new specs out of interest. its good to check your valve guides, they can wear and also get brittle from age. check your oil pump too man, make sure its not cracked or anything. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 17d Gender: Male Posted 26/04/12 06:38 AM Author Share Posted 26/04/12 06:38 AM The head is getting stripped next week to check valve guides and to see if any metal went in there.I'll be spewin if the oil pump is stuffed as it's only got about 1000km on it. All the gears will be pulled out on the weekend, checked and cleaned. If it's no good I'll consider putting a Nitto pump in it. Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 2m 23d Gender: Male Posted 26/04/12 09:59 AM Share Posted 26/04/12 09:59 AM if you do, make sure u put a 1.1mm head oil restrictor in and always fill with 6l of oil. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 17d Gender: Male Posted 26/04/12 09:57 PM Author Share Posted 26/04/12 09:57 PM That's the plan mic. I take it you've owned a GT-R before? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 2m 23d Gender: Male Posted 27/04/12 12:22 AM Share Posted 27/04/12 12:22 AM yeah I currently own one. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 17d Gender: Male Posted 27/04/12 12:45 AM Author Share Posted 27/04/12 12:45 AM What Model? Got any specs? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 2m 23d Gender: Male Posted 27/04/12 01:37 AM Share Posted 27/04/12 01:37 AM forged pistons rods oil pump and collar etc. race bearings cometic h/g ti v/s + retainers. arp head and mains line bore and torque plated block. everythin acid bathed crack tested new welsh plugs etc. evrythin u could do to make it bulletproof on the street basically. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 17d Gender: Male Posted 27/04/12 01:40 AM Author Share Posted 27/04/12 01:40 AM Sounds good. You said collar so I take it it's a 32? What turbo's and power are you running atm? Link to comment Share on other sites More sharing options...
