Losing Boost
thewoods
  • Member For: 15y 1m 6d
I dont think it would be the actuator as you've said it would drop then go back again. If the actuator is failing to hold boost it will just drop and stay down not surge like you have described.
  • Member For: 14y 4m 20d
im having a kinda of similar problem I changed and gapped my plugs a few months ago when I had a misfiring problem and checked coils which looked fine and not problem since but then I took the car in for new valve springs and a new diff since ive gotten it back as soon as it hits 3000 or so starts sputtering my mechanic mate thinks its the pump because he reckons the coils will generally fail on take off said it seems more like its not getting enough fuel could be a similar problem to yours... im going to get the pump changed this weekend and see if it fixes the problem
Edited by darkness
  • Member For: 14y 1m 6d
I've heard of coils failing as the boost increases and the spark has struggles more under compression. Sounds a bit extreme swapping the pump. Can,t you just get the pressure tested? I made a fuel pump pressure tester which fits under the car where the fuel rail hose clips to the metal fuel line. Most tuners will have one and could test the fuel pressure.
  • 2 weeks later...
