FG50T Member 568 Member For: 20y 11m 25d Gender: Male Location: Melbourne Posted 15/03/12 09:26 AM Share Posted 15/03/12 09:26 AM Long story short my stock exhaust is farked. Combination of possible blocked cat damage and rust increasing back pressure (after cat changed to a new one)If I'm going to go to the trouble of changing it I'd rather get a higher flowing one say 350rwkw. I'm not doing it for noise or a 'great note' because I believe such a thing doesn't exist for this motor. I'd consider a custom job if someone can nominate some good straight through mufflers Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 11d Gender: Male Location: @ my laptop Posted 15/03/12 09:29 AM Share Posted 15/03/12 09:29 AM If you want 1 off custom to your requirements, you will not do any better than seeing Barney at Hallam exhausts, make sure you talk to Barney and mention that I sent you down Link to comment Share on other sites More sharing options...
dre Resident idiot. Donating Members 2,068 Member For: 14y 4m 18d Gender: Male Location: Melbourne Posted 15/03/12 10:26 AM Share Posted 15/03/12 10:26 AM +1 for Barney. Really knows his stuff. Link to comment Share on other sites More sharing options...
FG50T Member 568 Member For: 20y 11m 25d Gender: Male Location: Melbourne Posted 16/03/12 07:26 AM Author Share Posted 16/03/12 07:26 AM Is that who did your F6 exhaust and modded your stock tips to fit it dre? Was yours Manta or custom? Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 3m 16d Gender: Male Posted 16/03/12 07:30 AM Share Posted 16/03/12 07:30 AM +2 for Hallam exhaust Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 8m 27d Gender: Male Location: Gold Coast Posted 16/03/12 10:26 AM Share Posted 16/03/12 10:26 AM I know you said long story short mate but given the factory system is S/S, rust shouldn't be an issue. If you can confirm what actually failed you may only need to swap the cat or maybe a muffler.I considered an x-force 3.5" full system for my car and be done with it. Trouble with that though, it most likely would've caused boost creep and I didn't want to spend $800 doing a turbo mod on the little huffer. So if keeping the stock dump, I'd weld in a 100cpsi cat and buy the manta 2.5" twin catback. They're better quality than x-force (who don't do a catback) and will cost you a $1,000. It will easily support the power you're chasing without the need to mod the turbo. They do actually make the things sound half decent also, lol. Good luck with it. Link to comment Share on other sites More sharing options...
FG50T Member 568 Member For: 20y 11m 25d Gender: Male Location: Melbourne Posted 16/03/12 11:52 AM Author Share Posted 16/03/12 11:52 AM Appreciate the suggestion. WIll def look into Manta 2.5 Link to comment Share on other sites More sharing options...
possum Donating Members 553 Member For: 15y 8m 15d Gender: Male Posted 16/03/12 12:00 PM Share Posted 16/03/12 12:00 PM I know you said long story short mate but given the factory system is S/S, rust shouldn't be an issue. If you can confirm what actually failed you may only need to swap the cat or maybe a muffler.I considered an x-force 3.5" full system for my car and be done with it. Trouble with that though, it most likely would've caused boost creep and I didn't want to spend $800 doing a turbo mod on the little huffer.So if keeping the stock dump, I'd weld in a 100cpsi cat and buy the manta 2.5" twin catback. They're better quality than x-force (who don't do a catback) and will cost you a $1,000. It will easily support the power you're chasing without the need to mod the turbo. They do actually make the things sound half decent also, lol. Good luck with it.no need to do waste gate mods on the little fg xr6 turbo as it can't flow enough to start with boost control doesn't become an issue with a decent exhaust Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 11d Gender: Male Location: @ my laptop Posted 16/03/12 09:52 PM Share Posted 16/03/12 09:52 PM no need to do waste gate mods on the little fg xr6 turbo as it can't flow enough to start with boost control doesn't become an issue with a decent exhaustBel's G6ET would run a minimum of 16 psi in the midrange with 0 duty cycle commanded to the wastegate solenoid with the Nizpro 4" exhaust fitted, this figure jumped to nearly 18 with a Stainless" Turbo side air intake, the port does need to be modified to run lower or controlled boost with a big exhaust and free flowing intake side.The Turbo itself does not flow enought though to maintain high boost in the top end Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 8m 4d Gender: Male Location: Perth NOR Posted 17/03/12 12:54 AM Share Posted 17/03/12 12:54 AM With my Xforce 3.5" turbo back my boost was spiking up to 18psi(sometimes more) before trailing right back at the top end. After the waste gate mod this was bought back and is able to be held at 15psi(still does trail off a little at the top end). Still using the factory CAI though so this probably has some effect up the top end getting enough air in? Link to comment Share on other sites More sharing options...
