Lime Turbo Donating Members 26 Member For: 13y 11m 20d Gender: Male Location: Perth Posted 15/03/12 05:14 AM Share Posted 15/03/12 05:14 AM Hello everybody, sorry this is so long!So I havnt had my xr6 turbo for long now, so I thought it would be a good idea to finish my ride. I know already that my 06 BF MKII XR6 turbo had a nizpro intercooler kit installed, along with a 4" downpipe, and twin 2.5" hotdog exhaust system, and bigger injectors, and a bullet (sniper) tune by BPT performance.that's great, but I wanted more, so ive then installed a walbro 300 lt ph (800hp rated) & fuel filter, as well as 3" cold side, and 2.5" hot side piping for the nizpro intercooler. (This together removed the cross-over), and fitted a 4" induction kit and air box (plazmaman) which goes in place of the original battery. (still waiting for second tune)Now I gave you all that detail for a reason, the problem is starting the car, dont get me wrong it starts everytime..... but at a cost. I have to wait for the fuel pump to stop whining & make sure my stereo Amplifier isnt on at the same time (running twin subs)..... otherwise nothing!! I personally installed the battery in the boot with 0 guage cable, and a 250 Amp fuse inbetween to protect myself. I also earthed the battery at two different places in the boot (its properly installed, even with gold plated contacts) I should also note that I bought a new (sealed) battery at this time as the other battery had dead cells (shat itself), I drove the car home without the battery functioning that time, so the alternator must be working fine, correct? ....... I was stuck I had to do it!I am completely lost what the problem is, I should be able to just get in my car and start it, but I have to leave the ignition on for a few seconds before turning it over. I know it isnt the startor motor because I have just replaced it (same size as original battery) !! Should I buy a second battery and have two, one for the engine and the other for audio? Will this fix the problem? You should also know that if I do turn the key without waiting, all I hear is a clicking noise? This has only happend since ive had the fuel pump and amplifier installed, and the battery moved (all installed personally).If anybody has any idea at all, any pointers or facts that could help, PLEASE let me know I will greatly appreciate it,Luke Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/ Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 28d Gender: Male Location: Christchurch, New Zealand Posted 15/03/12 05:28 AM Share Posted 15/03/12 05:28 AM (edited) If you have a big audio setup there is a different type of battery that you should be using as it is designed for the large draw that the audio system will always take. In saying this that may not be the only problem but seems like it would be.Edit: Check this out, it might help Edited 15/03/12 05:32 AM by Wenier Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210198 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 7m 18d Gender: Male Posted 15/03/12 05:30 AM Share Posted 15/03/12 05:30 AM Clicking means dead battery,, but weird that works sometimes Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210200 Share on other sites More sharing options...
Lime Turbo Donating Members 26 Member For: 13y 11m 20d Gender: Male Location: Perth Posted 15/03/12 06:45 AM Author Share Posted 15/03/12 06:45 AM Yeah thanks guys,Ill go get my new battery tested, and might get my alternator checked while im at it. If its the battery not having enough oomph, then that's an easy fix.... just means I bought a battery for nothing haha.... I should have asked here first Thanks for your help, ill keep you informed even if it takes a while to figure out So next question is, where do u recommend buying a perfomance/high crank battery from? Im in Perth? Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210227 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 19d Gender: Male Posted 15/03/12 08:13 AM Share Posted 15/03/12 08:13 AM A capacitor for the audio system may help? Battery install sounds spot on Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210273 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 1m 8d Gender: Male Location: Gold Coast Posted 15/03/12 10:09 AM Share Posted 15/03/12 10:09 AM Definately get the altinator checked after running with no battery. An auto elec once told me that people who run they're cars without the battery connected help keep him in business. Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210344 Share on other sites More sharing options...
Lime Turbo Donating Members 26 Member For: 13y 11m 20d Gender: Male Location: Perth Posted 15/03/12 12:46 PM Author Share Posted 15/03/12 12:46 PM @ Bionicxr6t05 - Do you think buying a bigger battery (Higher Crank Amps) & a capcitor will help, im running a digital sony amplifer with twin Alpine Type S 12" Subs & a Pioneer Deck, The amp pumps out 250RMS to EACH Sub?@ Gasman - Thanks for the tip, ill deffo get that checked. Do you have any idea how expensive a new alternator is.....incase they give me the bad news :/ And probably a stupid question but is there any alternators that are better than the stock one? Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210438 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 1m 8d Gender: Male Location: Gold Coast Posted 15/03/12 06:56 PM Share Posted 15/03/12 06:56 PM Never had to buy one but read here the bosch Item is inexpensive Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210463 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 19d Gender: Male Posted 15/03/12 08:27 PM Share Posted 15/03/12 08:27 PM If the battery wasnt completely open circuited the alternator should be ok but its easy enough to test, even without a capacitor I think an optima yellow top would be sufficient to run what you have and start the car perfectly, are you SURE your starter motor is ok? Test current draw while cranking under the conditions in your first post Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210497 Share on other sites More sharing options...
Lime Turbo Donating Members 26 Member For: 13y 11m 20d Gender: Male Location: Perth Posted 16/03/12 10:13 AM Author Share Posted 16/03/12 10:13 AM UPDATE: FINALLY!!Hopefully there is some useful information here, and I dont sound like an idiot hahaSo I took the car to a battery and electrical shop, the guy tested my battery, and found it had 450 cranking amps (when it stated 600, "super charge" brand).....should have know!He then tested my alternator and everything is fine in this area, was charging the battery fine and maintained when accelerating....if that makes sense.The guy then checked my two earthing cables which were installed in my boot, he said they were way to thin (wrong guage), he he cut me some new higher rated cable, crimped it and put a better, thicker, bolt through it (I now only have one earth cable) - apparently the bolts and washers I used for the earth were s**t as well lol.......funny coz I checked with a guy in jay-car before I bought anything, wanted to do it right the first time.I then bought an equivelent battery to an optima (same battery structure, but had a higher higher CCA), replaced the old battery and he then tested the car again with the new battery. This battery was putting out 1050 Cranking Amps.....no Bulls**t! and the new earth helped as the car now starts on the dot. every time. The battery cost me $320 bucks, he done the rest for free. and it solved the problem......finally Thanks for all your help Link to comment https://www.fordxr6turbo.com/forum/topic/79315-starting-my-xr6-turbo-possible-fault-after-mods-or-power-failure/#findComment-1210879 Share on other sites More sharing options...
